Router or DNS problem?
- Router or DNS problem?
01-06-2012 12:58 PM
Have been having intermittent but ongoing issues with dropped internet connetions for about 2 months now, and had posted previously about suspected DNS issue. However, having looked at posts in other threads am not so sure.....
Background: problem manifested itself at around same time as upgrade to 21CN
Problem: Internet connection fails randomly and states DNS problem.
Resolutions: Usually try the Windows 7 or Plusnet Assist fixes, but always eventually requires turning router off and back on. This always works.
Attempted solutions: Initially changed DNS settings to Plusnet. Same thing happened; Changed DNS this week to Open DNS and followed followed info to flush router. Same thing continues to happen. DNS settings changed in both router and pc. When no connection, have tried accessing BBC via IP address at 212.58.341.131 that was posted on another thread. Cannot access that.
So, having tried other DNS settings and not being able to access directly to IP address when the fault is present, does that narrow it down to a router fault? Am using a Netgear wireless DGN 2000 modelt which is less than two years old, and which never had any connection problems prior to this.
Any advice much appreciated.
NewStu
Re: Router or DNS problem?
01-06-2012 1:39 PM
If this does continue to happen we'd advise using the fault trouble shooter here: http://faults.plus.net
01-06-2012 1:42 PM
C:\Users\John>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.50]
over a maximum of 30 hops:
1 3 ms 1 ms 1 ms dg834 [192.168.0.1]
2 33 ms 16 ms 15 ms lo0-central2.ptn-ag02.plus.net [195.166.128.206]
3 14 ms 14 ms 24 ms gi2-12-221.ptn-gw01.plus.net [84.92.5.145]
4 14 ms 14 ms 14 ms vl55.ptn-lb01.plus.net [212.159.2.124]
5 15 ms 15 ms 14 ms cdns02.plus.net [212.159.13.50]
Trace complete.
01-06-2012 1:50 PM
Thanks for the suggestions. Will try the fault troubleshooter next time it happens, although will presumably only be able to do so once have re-booted the router.
Have tried the tracert previously when the fault is present and it failed. Ping failed too, but will do so again just to check.
Guess that might suggest a general internet fault as opposed to a DNS issue?
Will have a go this evening when home from work and post results.
NewStu
01-06-2012 1:53 PM
01-06-2012 1:55 PM
NewStu
01-06-2012 1:57 PM
C:\Users\Stuart>tracert www.pls.net
Unable to resolve target system name www.pls.net.
C:\Users\Stuart>ping www.plus.net
Ping request could not find host www.plus.net. Please check the name and try aga
in.
C:\Users\Stuart>
01-06-2012 2:21 PM
tracert 212.159.6.9
The output should be very similar.
01-06-2012 2:37 PM
thanks for the advice
06-06-2012 11:23 AM
Just to update, have not had recurrence of problem since 1st June, about a day after I switched to OpenDNS. Hopefully issue now resolved.
Thanks for advice given
NewStu
13-06-2012 9:53 PM
14-06-2012 12:20 AM
14-06-2012 12:30 AM
14-06-2012 3:42 AM
Make a note for future reference, in case there is a pattern.
Then login to the modem/router, on the main menu, under Maintenance select Router Status and at the bottom select Connection Status.
Click on Disconnect to drop your PPP Internet session.
When it's disconnected, (you may have to refresh the page to see it), you can then click on Connect.
In your browser you can then Check which Gateway you are now on. This is known as doing a Gateway hop.
If that doesn't work/solve the problem, or if it's occurring too frequently, do a Disconnect and then set the DNS servers manually on the Basic Settings screen - change from Get Automatically to Use These DNS Servers as mentioned in this thread as it sounds like a similar problem as has been seen on some recent Netgears (not just the router being used on fibre). Click Apply before leaving the screen.
Just a further thought, has this only been happening lately, in the early hours? It could be caused by the loss of PPP session as a result of BT network maintenance eg. as detailed here. There has been work in some previous weeks if you look back through the archives. I've seen several posts now with people having funny problems with reconnecting after this work. See this post for example.
15-06-2012 1:06 PM
I changed my DNS to Open DNS and went through the flush process that it recommended and have not had any problems since, which is about 14 days now. Prior to that, I was having daily problems and had tried a variety of fixes, including using the manual PlusNet DNS settings rather than automatic detection. Had to switch router off and on to connect, which was tedious.
Worth having a look at at link below
http://www.opendns.com/home-solutions/
NewStu
