Router not seeing modem
- Router not seeing modem
24-03-2014 11:15 AM
If I telnet in and try
=>dns server route list
I get nothing listed. Do I need to do something to make the router see the modem?
Re: Router not seeing modem
24-03-2014 11:28 AM
24-03-2014 11:51 AM
24-03-2014 12:03 PM
24-03-2014 12:50 PM
24-03-2014 12:57 PM
24-03-2014 1:06 PM
24-03-2014 5:14 PM
24-03-2014 5:26 PM
*Lan2 on the openreach modem will only work if its an unlocked unit.
Thx
24-03-2014 6:22 PM
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
It will prove if the spare modem is connected and working.
24-03-2014 9:34 PM
Quote from: Jaggies And the spare router has the fibre modification done? If it's an ADSL version it won't work...
Ah, I'm not sure about that. Any way I can find out?
Quote from: Webif It is in Lan1* on the Openreach modem * to Wan
It is.
Quote from: npr Have you tried a direct connection to the BT modem.
I hadn't. I'll give it a try.
I've now tried replacing the router as well as the modem (with a TP-Link TL WR841N, which Google tells me should be compatible) but when it tries to connect, it gets a "Timeout waiting for PADO packet". I *think* I've configured it correctly. Don't know if that information is helpful?
24-03-2014 10:36 PM
Error 651: The modem (or other connecting device) has reported an error.
I'm guessing this means my spare modem hasn't had the conversion for fibre as Jaggies suggested?
24-03-2014 10:56 PM
Jaggies was referring to your spare router - if it was another TG582n then it could have firmware that makes it unsuitable for FTTC
24-03-2014 11:10 PM
dick:quote
25-03-2014 12:59 AM
If you Google "pppoe error 651" there are 56000 results, so it appears to be a common issue. Looks like the raspppoe.sys file is the culprit. How you fix it is dependent on the OS version you are running.
