Router not connecting to internet - reporting wrong username and password.
- Re: Router not connecting to internet - reporting ...
18-12-2015 8:03 PM
Hi, my account went live tonight and i followed the instructions to set up the router but it's still not working. The internet light on the router is red and when i log in to the admin panel it tells me that the username and password is incorrect. Actual error message:
"We couldn't connect you to the internet. Please check your username and password and press the Connect button"
I've tried a factory reset and checked the username and password are correct multiple times but it's still not working.
Can anyone give me a hand?
Thanks.
Thanks.
Message 1 of 4
(1,635 Views)
3 REPLIES 3
Re: Router not connecting to internet - reporting wrong username and password.
18-12-2015 8:13 PM
To log in to the router interface the user name and password will be on the card that cane with the router and also on a label on the bottom of the router.
Once you are in there you need to check the login name which will be username@plusdsl.net where username is your user name. The password is the one you use to when logging to the portal.
Message 2 of 4
(1,138 Views)
18-12-2015 8:19 PM
Yep, i've done that. The username and password are correct, checked multiple times. It's still not working though.
Message 3 of 4
(1,138 Views)
19-12-2015 9:50 AM
You need to contact Plusnet via phone or chat and ask them to check if your account has been activated.
Message 4 of 4
(1,138 Views)
