Router and Profiles
- Router and Profiles
- « Previous
- 1
- 2
- Next »
Re: Router and Profiles
10-10-2011 5:42 PM
jono
11-10-2011 6:51 PM
any info please ?
regards
Jono
11-10-2011 6:56 PM
Could Matt advise please. As you can see it says channel mode Interleave
DSL Connection
Link Information
Uptime: 0 days, 0:15:07
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,240 / 7,968
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,808
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 20.30
Output Power (Up/Down) [dBm]: 12.0 / 8.0
Line Attenuation (Up/Down) [dB]: 0.0 / 4.0
SN Margin (Up/Down) [dB]: 29.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 546
CRC Errors (Up/Down): 0 / 35
HEC Errors (Up/Down): 0 / 43
regards Jono
12-10-2011 9:17 AM
Looks like the order was placed but changed interleaving from on to auto, so it's still in effect - sorry about that. I've placed a manual order to turn it off which should complete for you tomorrow.
12-10-2011 1:44 PM
Mind I had a look out of my back window yesterday and about 10 work vans were parked outside the exchange, but I would have thought what they are doing should not affect my broadband, i think they are working on the fiber optic.
Any clarification would be appreciated
DSL Connection
Link Information
Uptime: 0 days, 18:16:38
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,224 / 7,808
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,648
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 198.96
Output Power (Up/Down) [dBm]: 12.5 / 8.0
Line Attenuation (Up/Down) [dB]: 0.0 / 4.5
SN Margin (Up/Down) [dB]: 29.0 / 10.5
FEC Errors (Up/Down): 0 / 341
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
regards
jono
12-10-2011 4:25 PM
Lines can vary from hour to hour or day to day, so you can often see this kind of fluctuation. Are the errors impeding your use of the internet?
Jojo
12-10-2011 4:37 PM
Thanks for the clarification anyway, I get on tests regular speeds of about 6mb, thought it would be higher than that with being so close to exchange but hopfully they will activate the adsl2 in the future.
regards
Jono
15-10-2011 5:59 PM
I'm having problems transferring the reading from BT so will enter manually.
Results are estimated adsl Max line 8mb so speed should be between 7and 8mb.
DSL Connection
Link Information
Uptime: 2 days, 7:25:14
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,264 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 268.30
SN Margin (Up/Down) [dB]: 30.0 / 8.5
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 0 / 316
HEC Errors (Up/Down): 0 / 364
17-10-2011 11:50 AM
I see it's back up to 7150 now.
Jojo
17-10-2011 12:05 PM
regards
jono
- « Previous
- 1
- 2
- Next »
