Router and PC and internet connectiobn not talking to each other, the b*stards.
- Re: Router and PC and internet connectiobn not tal...
28-01-2016 11:03 AM
Help needed desperately! My Thomson 585 won't connect to my PC and to phone Plusnet for help is taking 30 mins. I'm at my wits end. Have tried everything.
HELP!!!!!
HELP!!!!!
Message 1 of 6
(1,355 Views)
5 REPLIES 5
Re: Router and PC and internet connectiobn not talking to each other, the b*stards.
28-01-2016 11:07 AM
do you actually mean that your computer won't connect to the router or it won't access the internet
a few clarifications
are you trying to connect wired or wireless
which operating system is on the computer
does the computer show a problem with the network connection
Message 2 of 6
(756 Views)
28-01-2016 11:39 AM
Oldjim - thanks for your reply:-
It won't access the internet.
Wired. But wireless doesn't work either.
WIndows 10.
Yes. It's something to do with the router and/or password, possibly. It's very odd, all lights on router now green (although internet light is flashing constantly) PC says I'm connected, but when I try to get to my home page, it just comes up with a Plusnet page asking me to enter my password - that seems to be on a loop.
How I can post a question here and not have internet access is completely beyond me!
WIndows 10.
Message 3 of 6
(756 Views)
28-01-2016 11:42 AM
That sounds a bit as though your account has been blocked due to non payment (almost certainly by accident)
Unless staff on here pick it up you could try chat (if that works) otherwise just wait on the phone
Message 4 of 6
(756 Views)
28-01-2016 11:50 AM
Thanks for the message Jim
Hi Jeanners49,
I've taken a quick look at your account, nothing is blocked etc however your router does seem to be using an incorrect account password, to login to the screen that's coming up the username is admin and the password is the serial number of your router.
The DSL login password needs updating to your current account password, I'd suggest giving our tech support team a quick call if there are any issues doing this
Hi Jeanners49,
Message 5 of 6
(756 Views)
28-01-2016 5:29 PM
And suddenly all is back to normal. I've changed nothing! Just went out and had scampi and chips.
Feeling more positive; thanks for the advice!
Message 6 of 6
(756 Views)
