Router TG582n - mac filtering
- Re: Router TG582n - mac filtering
25-05-2013 4:14 PM
This router says it has the facility to deny access to specific users as shown on its ' device configure page'
This page has a 'Allowed on WLAN' option that does not work
Plus net engineers do not show the facility on their support computers and say it's not supported
I am using a imac and have done all the usual things like resetting the router , turning off the connected device first etc
Has anyone got this working?
Very useful for controlling child access
Message 1 of 7
(1,347 Views)
6 REPLIES 6
25-05-2013 4:20 PM
This should work:
http://npr.me.uk/telnet.html#macaccess
Message 2 of 7
(667 Views)
26-05-2013 2:30 PM
Many thanks for your efforts
It looks like it would work for a Windows PC but I can't get the command window up on a Mac
Plusnet can't explain why it's disabled
Message 3 of 7
(668 Views)
26-05-2013 3:09 PM
Open the Terminal app (located in Utilities) and run "telnet 192.168.1.254" that will get you on to the router.
That's RPM to you!!
Message 4 of 7
(668 Views)
26-05-2013 4:42 PM
Hi Dido
You made it very easy for me!
Many thanks for taking the time
Geran1
Geran1
Message 5 of 7
(668 Views)
26-05-2013 7:48 PM
No problem geran1.
Oh and that's just a picture of Dido, you can call me RPM, for short.
That's RPM to you!!
Message 6 of 7
(668 Views)
26-05-2013 9:04 PM
Glad you've got it working.
I don't remember seeing the "Allowed on WLAN" / Disable on WLAN working in the GUI of any Thomson router I've ever used.
Note:
You may also find the "TOD Access Control Schedule" of interest for parental control. Details on the same site
Note:
Message 7 of 7
(668 Views)
