Router Stats
- Router Stats
Router Stats
09-02-2009 6:45 PM
Hey Guys,
Do these look ok? I was suprised at how few errors I was actually seeing, could the router be reporting incorrectly?
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 5152 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: OFF
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.6 23.0
Attn(dB): 46.0 29.0
Pwr(dBm): 19.3 11.9
Max(Kbps): 5632 1104
Rate (Kbps):5152 448
G.dmt framing
K: 162(0) 15
R: 14 16
S: 1 8
D: 16 2
ADSL2 framing
MSGc: 1 1
B: 162 15
M: 1 8
T: 1 1
R: 14 16
S: 1.0858 9.0000
L: 1304 128
D: 16 2
Counters
SF: 4030761 4030829
SFErr: 49 0
RS: 274091794 34261043
RSCorr: 102593 0
RSUnCorr: 292 0
HEC: 43 0
OCD: 0 0
LCD: 0 0
Total Cells: 832618477 0
Data Cells: 42092170 0
Drop Cells: 0
Bit Errors: 0 0
ES: 41 0
SES: 0 0
UAS: 27 0
AS: 68522
INP: 0.68 1.00
PER: 1.90 1.96
delay: 4.34 4.50
OR: 29.46 28.44
Bitswap: 0 0
Total time = 19 hours 2 min 45 sec
SF = 4030761
CRC = 49
LOS = 0
LOF = 0
ES = 41
Mode: G.DMT
Channel: Interleave
Trellis: OFF
Down Up
SNR (dB): 6.6 23.0
Attn(dB): 46.0 29.0
Pwr(dBm): 19.3 11.9
G.dmt framing
K: 162(0) 15
R: 14 16
S: 1 8
D: 16 2
ADSL2 framing
MSGc: 1 1
B: 162 15
M: 1 8
T: 1 1
R: 14 16
S: 1.0858 9.0000
L: 1304 128
D: 16 2
Counters
SF: 4030761 4030829
SFErr: 49 0
RSCorr: 102593 0
RSUnCorr: 292 0
HEC: 43 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 41 0
SES: 0 0
UAS: 27 0
AS: 68522
INP: 0.68 1.00
PER: 1.90 1.96
delay: 4.34 4.50
OR: 29.46 28.44
Bitswap: 0 0
SF = 4030761
CRC = 49
LOS = 0
LOF = 0
ES = 41
Message 1 of 2
(911 Views)
1 REPLY 1
Re: Router Stats
09-02-2009 10:58 PM
At a glance they look fine. With that downstream attenuation, you're synchronising at a level I'd expect and the line's been up for almost 24 hours. The number of some of the corrected errors suggests that you might have interleaving switched on but that's not really anything to worry about unless you're an ardent gamer.
For some useful info on router stats, take a look here.
Message 2 of 2
(243 Views)
