Router Changed
puddy
Router Changed
My next door neighbour brought a speedtouch 716wl router from me because he decided he would like to use Plusnet VoIP service again.  I also reffered him to plusnet
His BT wiring was a bit of a mess so I cut the wiring and just left wires 2 & 5 connected  and I also fitted a BT-I plate to help get a better sync speed. I cannot get his sync speed any higher , its stuck at 7616 were mines the full 8128.  The BT exchange is a cross the road from us
I am not sure if interleaving his switched on or not (he plays Xbox games over the net), or if is line need 10days before it get a higher sync rate or his profile stuck?  I have re-booted his router everyday for the past 4 days
Jameseh can you reset his profile rate/or noise margin for me please?  I have posted Kev settings and puddy settings to compare settings
Puddy
edit:- forgot to say have used new filters and fitted new BT sockets for him
10 REPLIES 10
Fixes: 393
Re: Router Changed
That sync speed of 7616 is pretty much a giveaway that Interleaving is ON. Seems to be set on with quite a few new accounts recently.
zubel
Re: Router Changed
It's usually set on for *all* new accounts, afaik.
B.
puddy
Re: Router Changed
Thanks Guys
How do I get it turned off?
I had thought it could be turned off in connection tools on plusnet web page but I cannot find it listed
Kind regards
Michael
Fixes: 393
Re: Router Changed
I think you need to raise a ticket requesting it turned off.
Fixes: 1,483
Re: Router Changed
or there might be a button under connection settings in the member centre
James
Re: Router Changed
I can turn it off if you PM me the username.
James
Re: Router Changed
Which you've already done Smiley
James
Re: Router Changed
Order placed, ticket raised on the account as confirmation.
puddy
Re: Router Changed
Thank you Jameseh  his router now syncing at 8128 and said friend now gets faster speeds on downloads.
Thanks you all for the tip about interleaving
Below I have put 3 speedtouch router stats all show a different SN Margin (up/Down) [dB]
I am not sure if the numbers supposed to be higher or lower for a  better line
I know sync speed should be higher but not sure with other settings and which way the should all be for problem solving
Puddy
Oldjim
Resting Legend
Fixes: 63
Re: Router Changed
If you are synching at 8128kbps which is the ADSLMax limit then the higher to better
