Ring Door Bell Chime
- Re: Ring Door Bell Chime
06-12-2020 4:52 PM
Hi, I am looking for some help. I have managed to connect the ring door bell to my internet but can't get the chime to connect. Anyone any ideas? Thanks in advance
06-12-2020 5:07 PM - edited 06-12-2020 5:10 PM
Welcome to the Forum vonnie69
If you do site search in the box under the purple boxes Forum Blog Browse there are various links to questions about Ring Door Bells people have asked before
HD
06-12-2020 5:31 PM - edited 06-12-2020 5:32 PM
05-02-2021 1:31 PM
For anyone who finds this thread, here is how I solved the same problem:
The easy bit:
1. Split the 2.4/5ghz signal - see thread here - https://community.plus.net/t5/My-Router/Having-to-switch-between-2-4GHz-and-5GHz/td-p/1709284.
The tricky bit:
I kept getting failed to connect. Eventually, the Ring app would say something like "you previously tried to connect to X wifi, do you want to try again?". Even if this is what you want, you need to click no, then you get a list of wifi networks. Select yours and you should be prompted to enter the password. There was no problem after that.
The issue seems to be that without doing it this way, Ring was not giving me the opportunity to provide the wifi password, so the connection was never going to succeed.
