Restrict broadband usage
- Restrict broadband usage
19-02-2012 12:28 PM
DAK, is there a way for a home user to 'restrict broadband usage'.
i.e. throttle back on peer-to-peer or data streaming.
Message 1 of 5
(1,181 Views)
4 REPLIES 4
Re: Restrict broadband usage
20-02-2012 10:13 AM
Some software used for P2P (most torrent software for example) has settings for maximum up & down rates, possibly also time restrictions.
My son uses torrent software for certain (legitimate) game downloads (micro-torrent I believe), I have found the settings to restrict that.
Call me 'w23'
Message 2 of 5
(520 Views)
20-02-2012 10:40 AM
Depending on your account type you can use the manage my usage tool on the portal to set a cap so that you don't exceed your monthly allowance.
Also using view my usage is a good way of monitoring your usage habits to make sure you don't use too much too quickly if that's what you're worried about.
Message 3 of 5
(520 Views)
20-02-2012 11:26 AM
You used to be able to apply blocking using the Surf option: https://portal.plus.net/surf/
I have a feeling this doesn't work these days.
Message 4 of 5
(520 Views)
20-02-2012 12:58 PM
Message 5 of 5
(520 Views)
