Resetting Router
- Resetting Router
Resetting Router
02-02-2012 5:46 PM
No doubt the following setup may have something to do with it but would be grateful for comments,
1. Desktop computer is connected via Ethernet cable & is Running Linux.
2. Laptop connects using Wi-Fi and is using Windows 7.
3. The router is switched off when we are not on the internet.
I Do not wish to change the OS on either computer and would be concerned about leaving the router on 24/7
Re: Resetting Router
03-02-2012 12:43 PM
Is anyone there !
Comments or suggestions on my previous post would be helpful.
Thank you.
03-02-2012 12:46 PM
04-02-2012 3:10 PM
I Get this message no matter what web site I try to connect to except 192.168.1.254 which gets me to the gateway bit, oddly enough it shows I am connected but if I try to connect I just get the unable to establish connection.
All the green lights on the router are on.
I Can connect ok 3 or 4 times and when I do the connection never drops but then the next time I log on I get the unable to establish connection message ?
NB, Thanks for responding Nozzer I thought everyone had fallen out with me !
04-02-2012 6:59 PM
as if you turn off too many times this may cause your loss of connection
05-02-2012 9:42 PM
ECO
Technicolor offers its customers ECO labeled products. Next to carefully selected plastics and packaging to minimize the ecological footprint, the gateways benefit from a unique combination of hardware and software features that reduce power consumption substantially. For instance, a button at the front allows the user to disable/enable the wireless access point when its function is not required.
Suggests that they keep power consumption low (and even allow you to lower it by switching off the wireless when not in use), this is consistent with the intention that the device is left on to prevent DLM issues.
06-02-2012 12:47 AM
every time you turn it off 'the system' sees it as a disconnection and adjusts itself to suit
lots of disconnections = system that thinks it has a terrible connection
06-02-2012 10:24 AM
09-02-2012 5:52 PM
10-02-2012 11:24 AM
It varies depending on which service you're on really, though a reboot should only be required if there's some kind of problem or the service is slowing down. You're currently on the up to 8Mb/s service on the 20CN network and are getting the fastest speeds possible so unless you notice things slowing down significantly I'd recommend leaving the router on, you'd only really need to reboot if the connection needed to sync up at a faster speed after slowing down.
Hope that helps explain things.
