Reset of TG585v7 no internet
leslittle
Hi I had a red light on internet support told me to enter administrator as username and the CP code on box but it just keeps saying wrong user name or password, tried numerous combinations administrator and blank box, and all the others, but nothing so I have reset my box now I have a green light but still no internet, help been like this since last friday
4 REPLIES 4
LaurenB
Fixes: 131
Re: Reset of TG585v7 no internet
Hi @leslittle, I'm sorry for the issues being experienced when trying to get online and trying to log in to your router.
Can you please again factory reset your router (using reset hole on the back) and then follow the steps below again immediately after.
1) Open up a webpage and in the address bar type http://192.168.1.254
2) When you connect to this page, you will be prompted for a Username and Password. The username is 'admin' (lower case, if says 'administrator please amend) and the password is found on the back of the router and is starts 'CPXXXXXXXXX'.. please ensure the password is entered in upper case.
3) On the left, click the option that reads 'Broadband Connections' followed by 'Internet Services'
4) On the far right click the button that says 'Disconnect' so that it changes to 'Connect'
If it is already reads 'Connect' then you can leave this as is.
5) Click View More and this will prompt you for your username and password. Your username which is username@plusdsl.net and your account password and then press 'Connect'
Can you please let us know if the issue then persists.
 Lauren Barry
leslittle
Thank you for your response I will try this again when I get home
LaurenB
Fixes: 131
Thanks, let us know how this goes.
 Lauren Barry
leslittle
Hi Lauren
Thank you this is now working
