Reset my BRAS profile
- Reset my BRAS profile
Re: Reset my BRAS profile
01-02-2008 1:17 AM
If you find the IP Profile is still 6500kbps by mid-day (today as I post) restarting your router (once) can help to give it a nudge.
Does the portal High-Speed Broadband setting now show 6500kbps (as it should)? Once the IP Profile gets to 7150kbps the portal value should increase to 7000kbps within a few hours (it takes time for the delta report from BTw to be received and acted upon).
01-02-2008 8:22 AM
i will leave the router connected until i get home tonight and see what it says then.
this was taken from connection settings in my high speed broadband settings in pn account -
Your High-speed Broadband Service
Your current broadband speed is 5500 Kbps
many thanks
andy
01-02-2008 8:30 AM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4988 kbps
01-02-2008 11:51 AM
It looks like your profile has now been changed at this end, so you should now be able to gain the optimal speed that your line will allow.
01-02-2008 5:44 PM
some people are never happy!
thanks
Andy
01-02-2008 5:47 PM
It's essentially the same thing. If it brings you any peace of mind I can change this to 8000Kbps, but you shouldn't see any difference at all.
01-02-2008 6:34 PM
cheers
andy
02-02-2008 2:34 PM
Actual IP throughput achieved during the test was - 4958 kbps
The above is my latest bt speed test, could the 7150 figure be expected to increase or is that as high as it goes on an 8mb connection
cheers
Andy
02-02-2008 6:49 PM
cheers
andy
02-02-2008 9:18 PM
A
03-02-2008 1:08 AM
i also made sure the phone line wasnt running near any major electrical sources like extension sockets or heating boilers.
if you have a problem then post it in the community support forums and someone will help you.
i am 90% there with my issue.
i also upgraded to your way pro as i normally use my connection for gaming.
if your problem is a a one off or usually good but sometimes your speeds are down then it may be down to the number of people using your exchange, also known as contention.
http://www.adslnation.com/phpapps/catalog/product_info.php?products_id=105&osCsid=2o4svq7d7ot0tjfipn...
http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=21&products_id=118
http://speedtester.bt.com/.
good luck
Andy
03-02-2008 1:12 AM
Your current broadband speed is 7000 Kbps
What does this speed mean?
The speed shown above is based on your sync speed. This is always a little higher than the speed at which data will actually be downloaded over your broadband connection. Find out more about sync speed.
Find out more about up to 8Mb broadband by reading our high-speed broadband guide.
the above is taken off my pn settings, can you change this to [color=blue]8000 [/color] please.
thanks
Andy
04-02-2008 9:43 AM
I've changed this manually for you.
04-02-2008 6:25 PM
i have been getting some good speed test results as well, 6500+ which is the highest its been so many thanks.
all seems stable as well
cheers
andy
05-02-2008 11:05 AM
Glad that your speed is sorted now martin!
Your speed issue sounds just like what I am currently going through. Since the beginning of Feb I have had a very slow speed of 135kbps. I have spent time trying everything suggested in the plus support pages (and nothing has changed on the line, hardware added or moved or otherwise) to no avail.
The latest BT speedtest read like this:
"Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 135 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2464 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 117 kbps"
I have been restarting my router several times a day for the last 5 days in an attempt to have the hardware re-train/sync but it hasn't worked.
If any moderator can set/ask BT to retrain my profile that would be great! It's the only thing left to try that I can think of.
Many thanks,
Stoley.
