Requesting Reset of Speed Profile
- Re: Requesting Reset of Speed Profile
25-03-2013 10:49 AM
Hey all,
Hope I am requesting this in the right section.
Over the weekend I made some changes to the wiring in my house in order to hopefully claw back some speed on my awful sub 2mb/s connection. Do I need to contact plus.net letting them know that my line needs to be retested in order to see a speed increase (if any)? My speed seems to be a constant 1.87mbps no matter what I do to improve it so I'm guessing it has been capped at that as it did provides the most stable connection, but seeing as I just made changes I'm hoping that cap will increase.
Message 1 of 5
(823 Views)
4 REPLIES 4
25-03-2013 3:36 PM
I've checked over your connection and your speeds should be around the 3M/bs mark. Are you currently connecting wired or wireless and is this on more than one device?
Chris
Chris
Message 2 of 5
(468 Views)
25-03-2013 4:23 PM
Hi Chris,
Thanks for your reply. I'm using a wired 1gbps connection and I have two PCs connected via a switch upstairs to the router downstairs. Due to an issue with the wiring in my house I have to use a BT accelerator and connect directly into the master-socket otherwise my broadband speed drops to around 0.3mpbs. I had the master-socket moved at the weekend so now there is about 0.5m of RJ11 cable connecting the router to the master-socket. During my last BT visit I had 4.5mbps when he left, but within 12hrs it had gone back down to sub 2
Dave
Dave
Message 3 of 5
(468 Views)
25-03-2013 5:06 PM
Hi Dave,
I've placed a SNR on your line as it's been stable and the noise margin was little high, this will take around four hours to complete and hopefully we'll see an improvement.
Message 4 of 5
(468 Views)
26-03-2013 10:12 AM
Hi Chris,
Thanks for your help yesterday, checked when I got in last night and it was 2.87mbps, will keep monitoring it in case it goes back down again.
Dave
Dave
Message 5 of 5
(468 Views)
