Request to reset connection speed
j123
My ADSL connection speed used to be just above 7,000 kbps which meant I could get download speeds of around 5.5 Mbps.
After a period of noise on the line (it happens every few months but usually clears after a few days or a week or so) the connection speed is now stuck on 4,475 kbps even though the noise on the line cleared up two or three weeks ago. Rebooting the modem doesn't help. My download line speed is currently around 3.7 Mbps.
Any chance the Plusnet techies can put the speed back up again?
Copied from the router stats:
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 130 271
Attenuation (0.1 dB): 450 227
Output Power (0.1 dBm): 0 130
Attainable Rate (Kbps): 8676 888
Fixes: 235
Re: Request to reset connection speed
Sorry to hear this.
I've requested the line be reset for you and that should go through shortly
Let us know if you haven't seen an increase
 Matthew Wheeler
j123
The connection speed is now 7,374 kbps, however, the download speed is still stuck on 3.7 Mbps.
What determines the download speed? How can I get it back to the normal 5.5 - 6 Mbps?
Fixes: 538
Can you reboot your router letting us know how your speed looks afterwards?
I've made a change to the speed profile on your account to reflect the increase in your sync speed.
j123
Back up to 6.34 Mbps.
Thanks!
Fixes: 34
Thanks for letting us know, @j123
I'm sure @Gandalf will be happy to know this as well.
If you ever need more assistance just give us a shout.
All the best,
MoR
 MoR
