Request for reset of line
- Request for reset of line
31-01-2014 12:00 PM
account requesting: Abdulrahman3
current line speed: 37.6Mbps
estimated line speed (vdsl): 63Mbps
Can i have a reset of my line please so i can reach close to the estimated.
Message 1 of 4
(700 Views)
3 REPLIES 3
Re: Request for reset of line
31-01-2014 12:04 PM
Has your speed always been around 37? I'm wondering if you've been provisioned on 40/10.
I assume you are on Unlimited and not Essentials.
Message 2 of 4
(456 Views)
31-01-2014 12:17 PM
The estimate is good according to http://dslchecker.bt.com/ and you're already on 80/20, though the current profile is showing on the side we get our reports from at around 19Mb so something is going on - though there's not many disconnections shown on the line:
<img src="http://community.plus.net/visualradius/generated/image13911705629105.png"/>
Honestly not sure what to suggest, though might be worth looking at what's plugged into the master socket and that the faceplate is performing as it should be.
Having said that, perhaps try a direct connection from a PC to the modem to rule out anything the router might be doing? Details on doing that here: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Hope that helps.
Hope that helps.
Message 3 of 4
(456 Views)
31-01-2014 12:20 PM
Also it's worth noting that on Fibre we can't just reset a line, that can only be performed following an engineer visit. So if you still see poor speeds after following Matt's advice then you'll need to open a fault ticket with us here: https://faults.plus.net
Message 4 of 4
(456 Views)
