Reporting Faults
glloyd
Reporting Faults
Once upon a time it was easy to report a broadband fault but now it's devil of a job. Surely it would save a lot of time and money if it was made easier and far better than hanging on the phone for ever.
11 REPLIES 11
Fixes: 1,599
Re: Reporting Faults
Hi @glloyd
You can report a fault to us online at http://faults.plus.net still.
If you let us know over here once you've done this we'll be happy to pick it up.
glloyd
That would be OK if the damn thing was not off line.
RandallFlagg
Fixes: 75
Hi @glloyd
Thanks for coming back to us.
The fault link that has been provided can be used from any PC or browser enabled device with access to the internet, it doesn't need to be raised from within your premises.
Best wishes,
Dave
glloyd
The fault reporter was not working when I tried it. I now have a ticket open 179454015 but nothing has been checked.
MatthewWheeler
Fixes: 480
Thanks for raising it.
We'll get it picked up as soon as possible
 Matthew Wheeler
glloyd
Having waited for the fault reporter to work I'm still waiting for it to be looked at Question #179454015. I fail to understand how PlusNet continues to get high rating for customer service.
MatthewWheeler
Fixes: 480
Sorry to hear you haven't had a response.
I've chased this up for you and you should have a update shortly
 Matthew Wheeler
glloyd
Thanks Matt
glloyd
OR Engineer turned up early, nice bloke. However, so much for their test equipment. It shows no disconnections back to the 12th July despite PlusNet Radius graph showing many as does my router and even the connection speeds were wrong. Fingers crossed all the testing may reset something.
MatthewWheeler
Fixes: 480
That is odd.
I'd recommend monitoring the connection to see if the drops continue
 Matthew Wheeler
ejs
Aspiring Hero
Fixes: 25
It's not necessarily odd. The Plusnet radius graph shows PPP disconnections, while presumably the Openreach person would have been looking at historic DLM data showing DSL disconnections. It's quite possible for there to be PPP disconnections while the DSL remains connected. Router logs vary considerably depending on the router.
