Replacement BTO modem power adapter
- Re: Replacement BTO modem power adapter
07-07-2014 10:18 AM
Hi can some one on the DCT tell me is it possible to get a replacement power adapter for the BTO modem my sister brought her new dog around and it thought it was fun to pull on the wiring that was in the hall way one of which was the power adapter for the modem somehow it managed to snap it in half , I managed to find an adapter for something else i had that fitted and is around the same voltage requirements etc and it is powering the modem at the moment but i dont want to keep it that way just in case it's doing any damage to the modem also i dont know if the modem was damaged from the pulling of the wiring it seems to working ok at the moment.
if it is possible to get one how much is it likely to cost.
the Adapter that is broken says Leader electronics Model number - MV12-Y120100-B2.
Message 1 of 9
(1,224 Views)
8 REPLIES 8
07-07-2014 10:26 AM
As far as I'm aware, the only way to do that would be to arrange for an engineer visit to replace the modem/cables that are damaged.
If you'd like for us to arrange this, please raise a fault at http://faults.plus.net
Message 2 of 9
(830 Views)
07-07-2014 10:36 AM
Thanks for the reply Chris, is this likely to cost anything ?
Message 3 of 9
(830 Views)
07-07-2014 11:00 AM
Have you considered grabbing one off eBay (with or without the actual BT Modem !) ?
Maybe cheaper than an engineer call if it is chargeable.
Message 4 of 9
(830 Views)
07-07-2014 11:03 AM
I'll wait and see if the Engineer visit costs anything if it does and it's to much then i'll look into ebay
Message 5 of 9
(830 Views)
07-07-2014 11:06 AM
I would be surprised if there's no charge.
Message 6 of 9
(830 Views)
07-07-2014 11:09 AM
As it's damage to BT Equipment, it would be considered a chargeable visit, which is £60.
Message 7 of 9
(830 Views)
07-07-2014 11:11 AM
thanks for that Chris a bit much just to replace a an adapter that can be picked up for a tenner or so, think i'll look on ebay
Message 8 of 9
(830 Views)
07-07-2014 11:18 AM
No problems, thought that might be the case to be honest.
Message 9 of 9
(830 Views)
