Reoccurring fault - gets fixed, then returns.
- Reoccurring fault - gets fixed, then returns.
Re: Reoccurring fault - gets fixed, then returns.
19-05-2017 8:19 PM
I always think that it seems unlikely that SNRM changes or anything much affecting the DSL could cause wildly varying ping times. A low SNRM or any other issues that increase the DSL error rate would cause packet loss, but would not affect the latency of the surviving packets.
Perhaps setting up some sort of ping / latency monitor, such as the ThinkBroadband broadband quality monitor would be useful.
19-05-2017 8:46 PM - edited 19-05-2017 8:47 PM
The reason I reset again is because this time I got told to reset 5 minutes after the SNR was set again, but in the past I've been told 4 hours. My ping a little more stable currently, but something is still up.
I downloaded router stats but how do I set it up for the PN router?
And thanks, I am waiting for the confirmation email from Thinkbroadband so I can download it.
19-05-2017 11:24 PM - edited 20-05-2017 12:52 PM
Sorry, I should have asked which router? The 2704n is not amenable to being monitored. If it's the TG582n then see the link below for a guide to setting up most of the parameters.
20-05-2017 1:10 AM
No problem, I have a 2740n.
20-05-2017 9:43 AM
Testing your line is showing it in perfect condition with 0 errors.
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 5.1 | 11.0 |
SNR Margin: | 6.0 | 6.0 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 6118320 | 101821904 |
Speed: | 1268 | 20394 |
Maximum Stable Rate (KBPS): | 20416 | Fault Threshold Rate (KBPS): | 16333 |
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 86400 |
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 86400 |
Are you experiencing any other issues besides the latency?
20-05-2017 10:08 AM
Yes as far as I can tell everything else is fine, including the speed etc like you say. The latency is strange even when it's close to fine. I've had it sit at a steady 14-15ms in the past, but right now it's as low as 20 and jumping upto 30 (which is practically fine, just looks a bit jittery).
20-05-2017 11:21 AM
What other routers do you have besides the 2704n?
23-05-2017 11:18 AM - edited 23-05-2017 11:23 AM
Do you mean routers that I could test?
To update: I got an message yesterday saying they had set my SNR margin again as it was too low and I was advised to reset the router again. Testing this morning, the latency on my line is still playing up, it sits around 30-40ms and will jump into the 100s of ms, which is still not good.
Edit: latency going into the 1000s now.
23-05-2017 11:55 AM
23-05-2017 12:08 PM
Well I testing pings with google in cmd prompt, but games also show the latency issue. I will PM you the results.
23-05-2017 12:17 PM
Thanks for your private message.
Nothing wrong with that traceroute that I can see. Besides the high ping whilst gaming, are you noticing any performance issues? If so, is this with more than 1 game?
23-05-2017 12:23 PM - edited 23-05-2017 12:24 PM
No it's not just one game, it's any game and not just games, but when pinging in the cmd prompt to google. I have attached a screenshot to show how sporadic this is.
I have just noticed that on the PN router Helpdesk section it's showing:
Noise margin: | 33.6/6.1 |
Which seems pretty high?
I am not noticing any other problems really, I mean sometimes a webpage or video may take a little longer to load than normal, which could correlate with when I'm getting bad latency, but this isn't for sure. It feels like little "blips" in the line (as you can see from the screenshot).
And just to add, before I was getting pings of ~15ms, I'd settle for 30ms, but strange how it never goes below 28/29 now?
23-05-2017 1:10 PM
So I just done another speed test and it seems that the download/upload speed are also very jumpy. I usually get at least 15mbps and 1mbps up, but this time the download was jumping around that mark and the upload started at practically no speed and only reach around 0.2, which is probably explaining bad latency with hardly anything happening on the network.
23-05-2017 1:10 PM
Noise margin: 33.6/6.1 Which seems pretty high?
Don't worry about those noise margins, the downstream is at a target of 6 and it's currently at 6.1, the upstream is also targetted at 6db but it's at 33.6 which means there's a good amount of overhead on it. The upload is now appearing as capped though, which won't be helping with latency problems. If something is maxing out the upload (very easy to do with a 440 upload speed) then this can adversely impact the download and latency.
I've placed an order to uncap this and it should complete tomorrow. Let us know how the connection is performing after that.
23-05-2017 1:16 PM
Okay great thank you.
Nothing is really being uploaded other than what is required for browsing/games etc. It just seems that the upload is so slow that even the smallest thing is maxing it out.
