Regular broadband, iPhone connection issue ?
bpascua
Hello,
I am new to Plusnet this week. Mostly things are working, I have an isseu with my phone which almost never wants to connect to the wireless network. I normally get "unable to join network X" and if I connect to my repeater which has worked for years (under SKY) it shows as "no internet connection" - Any advice here? I have an imac and Mac that seem to work OK? I posted about a IP security camera that was giving "incorrect password" and I suspect this is the same problem.
Any ideas? I thought this stuff just worked these days.....
17 REPLIES 17
JayG
Fixes: 4
Re: Regular broadband, iPhone connection issue ?
Which router do you have? If it's a Hub One this may be relevant:
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
bpascua
Hello,
Plusnet only have one router (the hub one) for regular BB. Anyway I reset the router to factory defaults and all seemed to be working. Strangely I changed the SSID to Applenet-PLUS  and I slowly began getting the issues again. It might be coincidence.
Support want to send me a new router. As of this morning I did another factory reset and left the SSID as the normal plusnet one and everything is working, my ipads and iphones can connect normally. So I will leave it like this. I cant imagine how changing the SSID can effect anything though?
thanks
bpascua
And the the one hub is only 2.4GHz......
Fixes: 94
If you are on standard ADSL broadband then you will probably have a Hub Zero, which is single 2.4GHz band only. Fibre customers get a Hub One which is dual band.
bpascua
Hello,
So i have made some progress, the way I have managed to get my ipad/iphones on the network is by setting the router to 802 b/g/n up to 300mbs in the wifi settings. Support said this shouldnt make any difference, but it seems to. That said my service has been up and down for the past 2 days so who knows...
Fixes: 291
Sorry to hear you're having issues.
I can see you spoke with us yesterday and a new router has been ordered. As you've managed to resolve the issue yourself I've cancelled this for you as it wouldn't make any difference.
With regards to the drops it's certainly been intermittent as shown below
We've tested your line but we can't see any cause for this.
Can you try going through the steps shown here and let us know how you get on?
 Matthew Wheeler
bpascua
Hello Matt - I forgot to mention that I also replaced my microfilter with the old SKY one, so that may have fixed the issue for me also.
thanks
bpascua
OK Matt - I am back to not being able to connect Iphones to my Router. Could you please ship me a new router as planned to see if that helps?
bpascua
So I am back to square one. Although I have 2 x Macs working with the WiFi, neither iPhone can join the network? I either cannot the regular cannot join, or the no internet in the picture....
Any ideas? I am already regretting leaving BSKYB....
bpascua
iphones are both on IOS 12.1 in case that helps.
Fixes: 94
Can we start again? Are you on ADSL or fibre and which router do you have, see https://www.plus.net/help/broadband/router-setup-guides/?
The reason I ask is because you say you have set the wireless to b/g/n mode. These are the only three available wifi modes on the single band Hub Zero. If you have a Hub one with ac mode as well then that is a dual band device and you need to split the bands as advised earlier.
bpascua
Apologies. I am on ADSL and have the 2704n router. My wireless channel is 11 and has only me on it from scanning. I have a PC, Imac and macbook that seem to connect and work just fine. I have 2 iphones and an ipad that I can get on from time to time but drop off after long.
Fixes: 43
Hi @bpascua,
I'm sorry to hear that you have experienced this issuer with your services. I've tested the line today and raised a response regarding this issue via a ticket on your account, which can be viewed here.
Please let us know once you've been able to respond to the ticket so that we may pick this back up as soon as possible.
 Alex H
bpascua
So in a nutshell I have the following. I have an IMAC and Macbook that seem to hold their connections. I have 2 iphones and ipad that cant connect at all. I either get cannot connect on the wireless screen or I have a wireless extender, which if I connect to says no internet.  I have reset the network settings on both, sometimes this means I get a connection, mostly not. If I leave the house and come back I begin another 30 minutes of trying to get wifi. Today I got a replacement router which is behaving the same as the old one.
The router is in the same place the old sky one was. I flipped over from BSKY where I had no issues with wireless interference. I have scanned and I see nothing on channel 6  - which is where I have set my wifi to be. No matter how many times Plusnet tell me there is nothing wrong with my line I am not sure I believe it. Surely this is either the line or the router being nonsense?
Saying Plusnet don't support support wifi doesn't really help me.
