Recurring speed problems
- Recurring speed problems
21-11-2015 11:54 AM
I've been seeing a hugely variable connection quality recently (a few months). Speed is usually about 3 Mbps but I get periods where it drops well below 1Mbps and stays there for hours. I also get a few disconnects. Right now I have 0.5 Mbps and the broadband troubleshooter checker is off-line so I can't submit a ticket. In the past when I have submitted a ticket it seems that Plusnet do nothing for a couple of days then tell me it is OK, which leaves me no closer to bottoming out the problem.
Is there anything I can do to narrow it down?
Is there anything I can do to get it back to normal more quickly. Rebooting the modem often seems to reconnect back at the normal speed but then it drops again soon afterwards, which I guess is the system "training" to the optimum speed. I'm never sure whether rebooting helps or hinders this process.
Message 1 of 4
(959 Views)
3 REPLIES 3
Re: Recurring speed problems
21-11-2015 12:45 PM
Your connection does appear to be intermittent at times.
In addition your sync speed drops to around 800kb every week or so which may be the sign of a fault.
Where do you have the router connected to at the moment?
Message 2 of 4
(503 Views)
21-11-2015 1:15 PM
It's connected to the master socket via a 3 metre cable and a filter. In previous occurrences I have connected directly to the test socket without any improvement. Very occasionally we do get a little audible hiss/crackle on the phone but there is none there now.
In a previous incident someone somewhere did find and rectify a phone line fault (it will be in the ticket history I think).
I'm reasonably technical but I don't really understand how the speed adjustment thing works. Would a brief fault be enough for it to drop the speed for a day or two? I know it is (necessarily) slow to ramp the speeds back up afterwards.
Message 3 of 4
(503 Views)
21-11-2015 2:15 PM
Depending on the socket you may not need the filter
http://bt.custhelp.com/app/answers/detail/a_id/40231/~/check-your-wiring-and-set-up
Do you have any extensions in use or not?
Is the ethernet cable good quality cat5? It may have writing on it saying what it is.
Message 4 of 4
(503 Views)
