Recent resyncs
spraxyt
Resting Legend
Fixes: 75
Re: Recent resyncs
The current versions of RouterStats work fine on the Thomson TG585v7 and v8. Set the Thomson and ST585v6 and v7 radio buttons, tick login and remember password and enter the router login details (admin and CP,,, (serial number, all letters capitals)).
For configuring graphs I suggest following the guidance in this post.
David
Mav
Fixes: 514
Re: Recent resyncs
Thanks spraxyt.
That's exactly what I had done but when I looked at the Router Search Text tab it seemed like it wasn't displaying the relevant info. I should have scrolled down which I did this time.
I have had at least two more resyncs: one last night to around 4000 and my profile dropped to 3500 and again this morning about 6 hours ago:
Maximum Bandwidth (Up/Down) [kbps/kbps]: 928 / 5,056
Bandwidth (Up/Down) [kbps/kbps]: 832 / 4,896
Forum Moderator and Customer
spraxyt
Resting Legend
Fixes: 75
Re: Recent resyncs
I don't think there's any need to touch the Router Search Text tab unless setting up User Defined entries. The programmed in configuration knows where to find the standard values.
David
Mav
Fixes: 514
Re: Recent resyncs
Thanks spraxyt.
Actually, on top of the other issue I have found that I, too, am suffering from the upload issues with the v8 Thomson supplied last year by PN. Hasn't been used since then till now but upload on both my wife's PC and the laptop were reported as 0.1Mb yet my wired connection was showing as 0.7Mb.
I've now connected an old v7 which has sorted the upload problem.
Running RouterStats and will have to reboot in the morning as swapping routers caused the sync to drop to 4448 Sad
Mav
Fixes: 514
Re: Recent resyncs
I rebooted on the morning of the 22nd and have stayed at 4896 since yet my BT profile hasn't lifted to 4000.
Is there anything I need to do this end or is there a further problem?
jojopillo
Re: Recent resyncs
Hi Mav,
I'm not sure why these drops but it hasn't been up for 72 hours continuous.
Jojo Smiley
Mav
Fixes: 514
Re: Recent resyncs
Those were further reboots in the hope it would resync higher again.
It seems my assumption that as long as the sync didn't go back down I'd be ok was totally wrong  Sad
jojopillo
Re: Recent resyncs
Because the profile is only increasing by 500k it will take a lot longer to go up.
Mav
Fixes: 514
Re: Recent resyncs
Hi Jojo
The uptime is now almost 80 hours but no sign of a profile increase on BT's side.
Anything needing to be done?
Cheers.
jojopillo
Re: Recent resyncs
Hi mav,
It's about 70 hours at the mo, so I'm sure it'll kick in soon.
Jojo Smiley
Mav
Fixes: 514
Re: Recent resyncs
Something strange (another one :D). BT profile is still 3500 but the PN profile is showing as 4000. Don't know when it went to 4000 but was like it last night.
jojopillo
Re: Recent resyncs
What throughput are you getting? It updated at 18.18 last night. Smiley
Mav
Fixes: 514
Re: Recent resyncs
At best between 400/420KB/s
Mav
Fixes: 514
Re: Recent resyncs
BT profile lifted to 4000 sometime between midnight last night and 15:30 today Smiley
Throughput has risen to around 450/460KB/s.
