Recent line speed issues
- Recent line speed issues
26-11-2012 6:08 PM
Recently my speeds have been fluctuating. Hoping its an easy fix as I cant be bothered with too much hassle.
Have attached btspeedtester results and here is router stats.
DSL Connection
Link Information
Uptime: 0 days, 18:40:31
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,048 / 19,639
Output Power (Up/Down) [dBm]: 12.0 / 21.0
Line Attenuation (Up/Down) [dB]: 6.0 / 13.5
SN Margin (Up/Down) [dB]: 6.0 / 3.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 1,052 / 0
CRC Errors (Up/Down): 1,052 / 134
HEC Errors (Up/Down): 98,089 / 84
DSL Connection
Link Information
Message 1 of 5
(829 Views)
4 REPLIES 4
Re: Recent line speed issues
26-11-2012 6:14 PM
Hi
What speed is given for "Current Line Speed"?:
Message 2 of 5
(460 Views)
26-11-2012 6:51 PM
17.1Mb
Message 3 of 5
(460 Views)
26-11-2012 7:05 PM
OK, Ignore most of that. Seems the problem must be wireless. My wired and wireless used to give similar results but it looks like my wireless is dodgy. Everything on wire looks normal!!
Message 4 of 5
(460 Views)
26-11-2012 7:11 PM
Perhaps try changing the wireless channel of your router.
InSSIDer is good for viewing what networks are in your area. Most routers can auto-pick what they consider to be the clearest channel based on what they detect around them, but that doesn't necessarily match which channels are congested elsewhere in your home. Choose the best from 1, 6 or 11.
Message 5 of 5
(460 Views)
