Reboot of router
- Reboot of router
Reboot of router
10-04-2013 3:12 PM
Couple of weeks back, when the snow fell, my connection dropped after 6hrs I had to reboot the router which worked
Today again, "no snow" but power failures from about a mile away the same disappearing connection failure, same reboot.
But when I accidentally cut a wire in the garage and knocked the trips out, all I done was reset them and every thing came back on, including the router.
Why would it be then that a power failure else where effects the router in such a way that it requires a reboot?
Dave
Dave
Message 1 of 8
(2,186 Views)
7 REPLIES 7
Re: Reboot of router
10-04-2013 3:59 PM
I believe there's a simple answer to this one.
The reason you had to reboot when there was a broader power problem in the area is that the power to the cabinet would have been lost too.
With a localised powercut in your house the router should automatically reconnect to the cabinet and get you back online without any intervention.
Message 2 of 8
(667 Views)
10-04-2013 6:13 PM
That is what I also thought, then the lights blinked in the house, whole of the town, as I live within 1 000yds of the exchange, the long way round, not just over the field, I guess they would have the same problem, "power drip / jump"
Yip reset router again, not a big problem for me, but as I will be away for the next two weeks, what is the best way to tell sons / daughter how to reset the router.
I do it with the computer software, but my 3 ain't fully conversed in the way of computing, "rather play stupid Xbox"
Pull plug and pray when it goes back in, it will go?? (I would rather not give out the password for router)
Dave
dick:quote
Dave
dick:quote
Message 3 of 8
(667 Views)
10-04-2013 10:28 PM
OK guys, 4 reboots in 9hrs, lights have flicked on and off, house lights / street lights
Open to suggestions here, why does the router not reset or re-log on to PN ? Netgear DG834 type
I hope some one will give an answer, and also that I can find this post in two weeks time, off out'a the country
Dave
Dave
Message 4 of 8
(667 Views)
10-04-2013 10:39 PM
For the last point - click on your profile on the top menu and click on show posts
Regarding router I found that my DG834Gv4 was very sensitive to voltage dips.
It would reboot when nothing else in the house was affected other than a noise blip from my Creative speakers
Message 5 of 8
(667 Views)
11-04-2013 8:04 AM
Quote from: DaveMcC why does the router not reset or re-log on to PN ? Netgear DG834 type
Under Basic Settings, check that Idle Timeout is set to zero.
Message 6 of 8
(667 Views)
11-04-2013 10:45 AM
You could invest in an uninterruptable mains power supply, which would protect your router from mains fluctuations and short power cuts.
A typical relatively low power and low cost UPS would be something like this - Amazon : APC CS-350
If you also want to protect other equipment as well (like a PC), then you will need something similar but with more capacity.
Message 7 of 8
(667 Views)
11-04-2013 11:12 AM
Quote from: DaveMcC Pull plug and pray when it goes back in, it will go?? (I would rather not give out the password for router)
A 'clean' power down / re-power should re-start the router correctly and re-connect but do instruct them not to be too impatient when doing this!
Call me 'w23'
Message 8 of 8
(667 Views)
