Really slow internet speeds for the past week
- Really slow internet speeds for the past week
23-06-2020 11:48 PM
I have lately noticed that my internet really suffers, especially if I try to upload anything, like a picture or having a video call. The internet starts to dropout or would be so slow that it stops responding to anything (that's when uploading a picture, as an example). I tried restarting router several times but it doesn't seem to help out. Is it possible to know if you see any faults on my line?
Best Regards,
Edvardas
Re: Really slow internet speeds for the past week
24-06-2020 3:28 PM
I note that you have posted this on the ADSL board. Do you have ADSL with a Hub Zero modem router?
If so you are most likely suffering from buffer bloat. This is caused by the uploading data delaying the necessary handshakes required by the downloading data. The Hub Zero is particularly bad at handling this.
You might get an improvement with a different modem/router but if my assumption on ADSL is correct then maybe It’s time to upgrade to fibre.
24-06-2020 3:30 PM
Thanks, I will try another router as you suggested. However, here I still have no possibility for fibre (stoneage...).
11-08-2020 8:34 PM
So have tried resetting the router as I had no other router available and this did not fix the problem, will try tomorrow with another router which I just ordered. It ridiculous this can be such an issue during these days...
