Really good line to pile of smelly stuff...
- Really good line to pile of smelly stuff...
01-04-2011 7:49 PM
Then it all went wrong, my Netgear stopped being able to sync.
I swapped filters and used a modem to hook up, it sync'd but couldn't do any more than that (apparently it needs to kinda log on to BT's equipment, and it couldn't).
In desperation I tried another modem. It connected!
But the line stability stinks, and I can hear (very quiet) noises on the phone, whenever the phone rings, hangs up the ADSL line drops, and when the phone is in use the line drops every minute or two.
I've switched back to the original filter, but to no avail, i.e. it's the same as above.
Ideas? Thoughts?
Re: Really good line to pile of smelly stuff...
01-04-2011 9:28 PM
01-04-2011 9:38 PM
01-04-2011 9:45 PM
If there's noticable noise on the telephone try a quiet line test (dial 17070 and select option 2 - preferably with a wired telephone), if there's significant noise report to your telecoms provider as a voice line fault, any such noise indicates a line problem that will also cause Broadband problems but is not a 'Broadband fault' as such.
01-04-2011 9:48 PM
01-04-2011 9:56 PM
(unless you also 'hear the voices' when not using the telephone - sorry, couldn;t resist.)
01-04-2011 10:52 PM
would you be able to get your hands on another router? Has this noise only happened since you replaced the router?
Jojo
02-04-2011 1:41 AM
Yes, I believe so, although I use the phone infrequently as I use VoIP as my primary phone.
02-04-2011 7:46 AM
02-04-2011 8:04 AM
02-04-2011 11:15 AM
02-04-2011 11:54 AM
02-04-2011 12:35 PM
Quote from: fourfourdevon .Yes, I believe so, although I use the phone infrequently as I use VoIP as my primary phone.
Not sure then, I think it's best if we see what the faults team come up with.
Jojo
