Really Slow Broadband
tszyan
Recently I've been experiencing internet speed much lower than before. When I went to check the line speed, it says that my current line speed is only 2.7 Mb, which is much lower than the estimated line speed of 12 Mb. Is this the reason for my slow internet? If so (or if not), how can this be fix?
20 REPLIES 20
Fixes: 160
Re: Really Slow Broadband
A warm welcome to the forums.  There can be a multitude of reason why your broadband is (or appears to be) running slow.
Those speeds you have reported, are they from speed tests? If yes were they over wifi or a wired connection?  Best start with all of the basics.  Take a look at the speed issues topic - see the link below.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
tszyan
Thank you for your reply.
For the Kitz line check
Distance from the exchange:
Direct: - 464 metres
By Road: 0.8 km
For the Kitz BT checker
TG582n Router stats
DSL Connection
Link Information
Uptime: 0 days, 0:08:49
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,236 / 2,268
Data Transferred (Sent/Received) [MB/MB]: 33.73 / 447.08
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 17.8 / 30.0
SN Margin (Up/Down) [dB]: 5.5 / 18.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 11 / 18
FEC Errors (Up/Down): 0 / 1,824
CRC Errors (Up/Down): 500 / 0
HEC Errors (Up/Down):
756 / 0
BT Speed Test
Finally,
The current line speed: 2.7 Mb
BD
Fixes: 86
Hi there, sorry to hear your having broadband issues. I've had a check of your connection from this side and their definitely seems to be something out of place somewhere given the testing of your line below:
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status:   NTE Power Status: Unknown Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 17.8 30.0
SNR Margin: 5.3 18.0
Errored Seconds: 84 0
HEC Errors: 0
Cell Count: 63889 171174
Speed: 1236 2268
Maximum Stable Rate (KBPS): 14752 Fault Threshold Rate (KBPS): 11802
Mean Time Between Retrains (Seconds): 7825 Mean Time Between Errors Upstream (Seconds): 804
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 489
Custom Thresholds
MTBR_RED: MTBE_RED:
MTBR_GREEN: MTBE_GREEN:
It shows we are only getting just over 2.2Mbps to the router in terms of download and this will be because of the signal strength being set so high and from the looks of the profile the speed has been banded "WBC 1M - 2M Medium delay". This will be all done by the automated system to try and get around what ever is causing errored seconds with the connection. When running a test on your line however it didn't find a fault on the line despite the line quality showing red. It doesn't mean there isn't one there however and just means we need to run through a few checks your side before going down the route of raising a fault and getting an engineer out to investigate.
I'd recommend starting with basic checks here
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket and seeing if the speed returns without errors, I'm putting the settings on your line back to normal so you may notice an intermittent connection and some drops but this will allow you to see if any of the checks done get the connection and speed back to normal. How to locate the test socket and set your connection into it can be found here
Let us know how you get on your side and as mentioned if the steps above don't resolve the issue we will look towards raising a fault.
Kind regards,
Ben
tszyan
I've been through the recommended basic checks, and everything seems fine. My router is connected to the test socket yet that doesn't seem to have any difference.
Mustrum
Fixes: 77
Have you done a quiet line test with a corded phone?
tszyan
Yes, I did that as part of the recommended basic checks and I did not hear noises
Mustrum
Fixes: 77
Did the trouble-shooter take you through to be able to report a fault?
https://www.plus.net/help/broadband/connection-troubleshooting/
Fixes: 160
Can you please post new router stats?
Fixes: 1,600
Looking at your connection, something happened yesterday that caused no connection, since it's come back it appears to be more stable...
Your line is banded, likely as a result of those drops...
Profile Info: WBC 1M - 2M Medium delay (INP 4) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+)
I've just removed the banding now, should take effect within about 10 minutes.
You may notice the router resync as part of the process.
Let us know how your speed looks following that?
tszyan
Router Stats:
Uptime: 0 days, 15:30:54
Bandwidth (Up/Down) [kbps/kbps]: 1,240 / 13,995
Data Transferred (Sent/Received) [GB/GB]: 2.31 / 8.83
Line Attenuation (Up/Down) [dB]: 17.8 / 30.5
SN Margin (Up/Down) [dB]: 6.0 / 6.4
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 192 / 30
FEC Errors (Up/Down): 0 / 43,398
CRC Errors (Up/Down): 0 / 229
HEC Errors (Up/Down): 0 / 4,137
Estimated line speed:12Mb
Current line speed:2.7 Mb
Fixes: 160
Something odd here - was that current speed figure taken at the same time as everything else? The reported PN profile (current speed) does not correlate with the BT profile or the reported speed test results.
Makes me wonder if the PN profile (somehow) has no influence on your line?
Fixes: 1,600
I'm not in the office now but it's likely the connection profile on the account hasn't updated since I removed the banding. If they're provisioned on the dedicated network (I've stopped saying "new") then that profile will have little impact on the throughput.
Fixes: 160
Anoush,
That is what I've started to wonder given hints elsewhere. Is that little impact or zero impact?
Fixes: 1,600
As far I've seen, it's zero impact.
