Re: broadband speed
mmorris85
Re: broadband speed
hey all,
just a general question about speed, on that bt speed checker site, what sorta speed should i realistically get for a 17MB line? just curious really Smiley
34 REPLIES 34
Oldjim
Resting Legend
Fixes: 63
Re: broadband speed
Split off to its own topic - it is never good practice to jump into a problem thread with a separate question
orbrey
Re: broadband speed
@nmorris85: About that really, apart from the odd one the speed estimates are usually pretty good. Allow some margin for error though Wink
jelv
Fixes: 10
Re: broadband speed
It tends to report below the speed you might see from other testers. The crucial thing the BT diagnostic tells us is the IP Profile.
If you just want to see how fast your line can go use the Spped Test (beta), http://www.speedtest.btwholesale.com/, http://www.thinkbroadband.com/speedtest.html or speedtest.net (there's a link to the Plusnet Community speedwave on speedtest.net in my signature).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mmorris85
Re: broadband speed
Ah right ok, i tried bt speed checker and it came back saying 8.53mb, which seems a little slow if thats true Tongue
Oldjim
Resting Legend
Fixes: 63
Re: broadband speed
Please post the full results from the BT speed checker - diagnostic version - and also the Current Line Speed from https://portal.plus.net/my.html?action=data_transfer_speed
chrispurvey
Re: broadband speed
It would be good if you could post what jelv has stated from the BT speed checker.
I've checked over your account and your IP profile and it all seems to be matching up and you should be seeing speeds of 17MB/s, are you connecting wired or wireless?
mmorris85
Re: broadband speed
Hi chris,
This is what the latest test just told me, with a wired connection:
Download speed achieved during the test was - 2.04 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 16.37 Mbps
mmorris85
Re: broadband speed
Speedtest.net gave me 11.37mbps
mmorris85
Re: broadband speed
I just tried the BT speedtester beta link and it gives me a reading of 9.04mbs if thats any help
chrispurvey
Re: broadband speed
That's some very varied results, I've running some checks on your line and see we'll see where to go from there.
mmorris85
Re: broadband speed
ok thanks chris  Smiley
jelv
Fixes: 10
Re: broadband speed
What do you get from http://www.speedtest.btwholesale.com/ Could you also run http://www.bbc.co.uk/iplayer/diagnostics please.
I think this and the other thread are pointing to the idea that we should totally disregard the actual speed reported by the old BT speed test!
mmorris85
Re: broadband speed
ok trying that link i got this result:
Download speed achieved during the test was - 9.49 Mbps
IP Profile for your line is - 16.38 Mbps
Iplayer link gave me a download speed of 11.3mbps
chrispurvey
Re: broadband speed
I've run quite a few checks on your line and everything appears OK on your line, so it's I'm currently doing a bit more intrusive testing. Have you been able to try a speed test on another computer?
