Re: PPP Authentication error
Thruster
This has been happening to me since my connection was set up a few days ago.  Randomly disconnects and the router is unable to authenticate again until I manually log into it and hit connect.  The event log shows this:
"PPP LCP Send Termination Request [Failed to authenticate ourselves to peer]"
This is extremely irritating as sometimes I need to remotely access my PC, which is not possible when the router disconnects like this.  The line is stable, but it appears that the Plusnet PPPOE (or RADIUS) server just keeps failing to authenticate my router correctly.   Please sort this!
Moderator's note by Mike (Mav): Changed thread title after split to reflect issue.
4 REPLIES 4
MatthewWheeler
Fixes: 479
Re: Broadband keeps dropping off
Sorry to hear you're having issues.
Our tests aren't showing any issues but if the drops continue we'd recommend raising a fault here
 Matthew Wheeler
Fixes: 160
@MatthewWheeler,
Does your comment above apply to the OP or the piggy-backer?  I've asked the mods to split the piggy-backer off.
MatthewWheeler
Fixes: 479
@Townman It was in response to the piggy backer
 Matthew Wheeler
Mav
Fixes: 515
Moderator's note:
Split for better visibility and title changed to reflect issue.
Forum Moderator and Customer
