Re: My line profile and attenuation - podman's problem
- Re: My line profile and attenuation - podman's pro...
31-01-2011 12:17 AM
will check tomorrow. do pn need 3 days worth of crc errors to raise an issue what no. over what period would be an issue?
cheers,
podman
31-01-2011 1:31 PM
those errors are negligible so I wouldn't focus too much on them to be honest.
Jojo
31-01-2011 6:26 PM
is there anything that could be done to have the SNR reset to 6 or 9 as I have had before. it lasted quite a while when last done and made a difference to to sync. or am I clutching at straws in asking 🙂
Podman
01-02-2011 9:52 AM
It's always a possibility. Are you still in the test socket?
Jojo
01-02-2011 11:42 AM
the rate of crc errors and stats are the same between 2 routers and 4 filter all directly into the test socket and with and without the home phone plugged in.
anything you can do would be greatlt appreciated.
podman
01-02-2011 1:41 PM
The line's not looking too bad at the moment, let's see if there are no drops by tomorrow and I'l look at it again.
Jojo
01-02-2011 6:09 PM
podman
01-02-2011 8:20 PM
I have only just found last nights post re trying to reset the SNR
would it be possible to reset it just now 🙂
http://community.plus.net/forum/index.php/topic,92890.16.html (apollogies if I'm not allowed to inlcude that link like that)
podman
01-02-2011 8:45 PM
Yes, I will check it tomorrow and see whether an SNR reset will help.
Jojo
01-02-2011 8:48 PM
the wife would probably have been a bit miffed it a reboot was needed half way through her watching Silent Witness on iplayer
01-02-2011 11:31 PM
which should I be on ppoa does not connect.
podman
02-02-2011 9:19 AM
Did you investigate these settings because you lost connection?
Jojo
02-02-2011 12:51 PM
podman
02-02-2011 3:33 PM
As the old saying goes, 'if it 'ain't broke, don't fix it' I'll need to check it tomorrow now as I need a good solid connection to justify the reset.
Jojo
03-02-2011 3:34 PM
could you please have a quick check of my line to determine if it has been stable enough to request the reset.
I am due to switch to Adsl2 on 21cn this week would making this change to snr confuse things in the system / process?
Many thanks,
podman
