Re: High-speed Broadband
- Re: High-speed Broadband
09-08-2007 9:48 PM
I assume you are on a max or LLU connection, otherwise that tool will never show the correct info and for some you won't have the icon either.
Message 1 of 4
(1,198 Views)
3 REPLIES 3
11-08-2007 12:20 PM
Hi
I hadn't looked at this in ages. Mine now says that my connection speed is 500kbps! My router says 3774, speed test says similar. What's gone wrong with the tool.
(FOL user hulls)
(FOL user hulls)
Message 2 of 4
(339 Views)
11-08-2007 2:03 PM
Nothing is wrong with the tool, it is reflecting what BT have set on your line. Remember a drop is sync results in a drop in IP profile within 75 minutes but it takes 3 -> 5 days before it recovers after you sync at your normal rate again.
If you keep resyncing at different speeds then you will always have a problem with getting the best IP profile for your line.
Message 3 of 4
(339 Views)
11-08-2007 10:21 PM
Quote from: Peter Can a staff member please fix the High-speed Broadband tool (normally available here
I've corrected it for you.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 4 of 4
(339 Views)
