Re: Engineer visit not turned up
Freddie40
I had an engineer visit booked for between 1pm & 6pm today (7th Aug) when 6pm came & went & the engineer hadn't been I rang customer services to be told that BT had rejected the visit when the request had been made, but no-one had thought to oass the message onto me, so I wasted an afternoon & turned work down for nothing. The T&C's state that I will be charged £65 if I don't allow access or cancel with less than 48 hours notice, can I charge Plusnet £65 for failing to notify me???
9 REPLIES 9
Fixes: 1,600
Sorry to hear that @Freddie40
From what I can see the appointment wasn't booked in correctly, I'll make sure feedback is passed on about that.
With regards to the engineer fee we'd charge you if you missed the appointment while I appreciate what you've said, if you missed the appointment we're charged a lot more than £65 by our suppliers but we'd only pass on to you £65 of the charge we receive.
I can see we've rebooked the visit in for this Friday. If you can drop us a message over here once the fault is resolved we'll be happy to discuss a goodwill gesture with you for the inconvenience we've caused.
Strat
Fixes: 565
Moderator's note:
Posts split to their own topic for clarity.
Freddie40
Thanks Gandalf, hopefully no hiccups this time. I report back with the outcome.
I also take your point about the charge that is imposed on Plusnet but I might add that my losses could also have more than £65.
Thanks for your help.
Freddie40
BT Openreach turned up bang on time as arranged and did a thorough test & found nothing wrong with my line, but it has been working fine since Tuesday. He suggests a new router if problems return.
MasterOfReality
Fixes: 57
Thanks for letting us know @Freddie40
If the problems do indeed return give us a nudge and we can explore this option.
Freddie40
Thanks, can you also let me know about the gesture of goodwill mentioned above?Huh
Jubby
All Star
Fixes: 31
Hi @Freddie40
Please accept our apologies for the issue with your service.
I have replied to the question on your account which you can access here.
Please reply to the ticket and on here so we can pick it up for you.
Thank you.
 Lewis G
 Infrastructure Operations Professional
Freddie40
I'm still having regular drop outs with my service, not as often as before but still happening & it really is annoying. One of your customer service guys that I spoke to before said that if the problem persisted it may be worth trying a new router, the engineer that came out also said that it could be the router, but couldn't prove it has everything tested ok whilst he was here.
What do I have to do about geting a new router?
Fixes: 1,600
Sorry to hear you're still experiencing connection problems.
Our tests are showing a potential external fault "Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report" so I've reported this through to our suppliers now for further investigation and we'll update you when we know more.
