Range of Technicolour Wifi router
- ADSL Broadband
- Re: Range of Technicolour Wifi router
26-10-2013 12:48 PM
After the rave reviews about plusnet I signed up after many years with BT, cast aside my BT homehub2 and installed the new Technicolour TG528 router, and everything seemed fine, speed, dropout etc unaffected. Problem was when I went upstairs I just had no wifi signal and it ended about 15 feet short of where I routinely used BT, so now no wifi upstairs (where my home office is located!). Surprisingly PlusNet have been next to useless and after 1 week merely suggested I reboot the router (which had no effect), use a free channel ( which had no effect) and as a last resort to consult the community! so here I am, after hours of fiddling about trying to restore the level of service enjoyed for years...and a little peeved..........I am directed to ask if anyone in the community can advise what to do as PlusNet don't seem interested now I am signed up. So cn anyone help me? The question is can I reuse the BT router which seemed to have a much better range? or get some sort of signal enhancer to extend the wifi a bit further, even though this will wipe out the savings with plusnet but hey ho! Many thanks Chris
Message 1 of 8
(2,820 Views)
7 REPLIES 7
26-10-2013 12:52 PM
you should be able to use your BTHH2.
Message 2 of 8
(420 Views)
26-10-2013 1:27 PM
Hi Chris, welcome to the forum,
You can use the BTHH2, my sister had an old BTHH2 lying around and I borrowed it to see if it would work with PN. I plugged it in and it worked straight away.
Message 3 of 8
(420 Views)
26-10-2013 1:52 PM
Yep, Picked a BT HH3 from a car boot sale and using it now, wifi is much better than Technicolor
Message 4 of 8
(420 Views)
26-10-2013 4:01 PM
Quote from: JamesM Hi Chris, welcome to the forum,
well it won't work "straight away".
you'll need to manually enter your plusnet user name first.
Message 5 of 8
(420 Views)
26-10-2013 4:37 PM
Set-up instructions for the Homehub 2 & 3 on Plusnet can be found in the Community Support Library article Using a BT Homehub 3 or 2 on Plusnet ADSL or FTTC.
David
Message 6 of 8
(420 Views)
26-10-2013 5:57 PM
Quote from: chenks76
Well if you want to be pedantic, then you should also mention you need to enter your password too.
Message 7 of 8
(420 Views)
27-10-2013 12:02 AM
Message 8 of 8
(420 Views)
- ADSL Broadband
