Random disconnections still persistent with interleaving switched on.
- Re: Random disconnections still persistent with in...
- « Previous
- 1
- 2
- Next »
Re: Random disconnections still persistent with interleaving switched on.
14-09-2008 8:22 AM
Likewise, I am having the exact same problems. What is the alternative option?
Message 16 of 21
(391 Views)
14-09-2008 10:34 AM
Go to http://www.samknows.com/broadband/
and find your exchange
this will show you which wholesale Local Loop Unbundled operators on your exchange
Message 17 of 21
(391 Views)
14-09-2008 11:17 AM
That won't solve the problem if you are still on a BT copper loop. Better to stay with PN who will help you sort it than transfer the problem to another ISP and the help you might/will get will be sweet FA, especially if it is some of the 'big boys'.
You may all care to read my response to TJJ's thread here
Message 18 of 21
(391 Views)
14-09-2008 2:48 PM
It will be a long time before BT will change over to optic fibre. I was told by an openreach engineer it would be 2012 at the very earliest.
I have a choice of BT, wireless 3G (expensive) or cable.
My IP profile has increased to 3000 but I am only connecting at a pathetic 1MB, resetting the router does not help?
Mark.
Mark.
Message 19 of 21
(391 Views)
15-09-2008 4:33 PM
How about now Mark?
Our profiled speed will update after the BT one, so sometimes you have to wait a little for it to catch up.
Message 20 of 21
(391 Views)
15-09-2008 7:12 PM
Speed has improved now, but the problem is that the amount of disconnections increase as the broadband speed increases.
<a href="http://www.speedtest.net"><img src="http://www.speedtest.net/result/323869800.png"></a>
Message 21 of 21
(391 Views)
- « Previous
- 1
- 2
- Next »
