Radius Log Request
- Radius Log Request
Re: Radius Log Request
03-07-2015 7:31 PM
03-07-2015 10:49 PM
03-07-2015 11:21 PM
Just wondering what the promised thunderstorms will do - I'm going to risk it and leave everything running.
04-07-2015 9:30 AM
Not so much my interest as your commitment. That's a 33+% decrease in synch speed. Really need to get a profile on this so that the source of the REIN can be identified.
Kevin
04-07-2015 10:01 AM
I would dearly like to get to the bottom of this, but at the moment so long as I have a connection, I'll have to be satisfied.
Maybe towards the middle/end of next week when things have calmed down a bit, I'll be able to spend more time on what i need.
04-07-2015 10:20 AM
1. Best Effort Test: -provides background information.
Download Speed
6.74 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.74 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.75 Mbps
Upload Speed
0.64 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.64Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
05-07-2015 5:32 PM
Post #34 is the one with the figures we need to see.
A line of your attenuation (34dB) ought to deliver circa 12-13Mbps DS synch @6dB with ADSL2+ modulation.
That should give a profile in the region of 11Mbps - speed tests should be around 10.5Mbps.
A line synched without noise, later experiencing noise will see the SNRM fall below 6dB and possibly drop.
A line synched with noise, later experiencing no noise will see the SNRM raise above 6dB - this will lead to a lower error rate as well.
07-07-2015 9:42 AM
@ Kevin - no xDSL or PPP drops since that last catastrophic one. Odd DS SNRM fluctuations, but they don't last long & seem to recover to 12.7/13.1 quickly.
Will try and post relevant pics &c if I get half an hour later on.
07-07-2015 10:04 AM
That is exactly what we are looking for. Such events (if the SNRM were not so high) might have dropped the link.
Kevin
07-07-2015 1:43 PM
Thought I was getting an afternoon off, but no such luck. I'm afraid it's going to be earlyish tomorrow, but I'll leave everything running.
07-07-2015 5:30 PM
I was out this afternoon - came back and looked at router log as JDS was showing a new IP. Discovered there had been a PPP drop 14.45.06 - 14.45.26 - which didn't show on RS, but no change in SNRM or speed.
Just getting ready to post that snippet, and I've had TWO DSL drops #1 17.04.43 - 17.05.31 #2 17.07.25 - 17.08.12
Connected now @ 11.976 DS/0.780 US SNRM 5.9/6.1 DS /5.9 US.
Don't know how long it will hold - SNRM is fluctuating a bit.
07-07-2015 5:32 PM
Can you please post a VR plot?
Thank you,
Kevin
07-07-2015 5:41 PM
08-07-2015 1:17 PM
09-07-2015 7:58 AM
Uptime: 1 day, 14:23:25 DSL Type: ITU-T G.992.5 Bandwidth (Up/Down) [kbps/kbps]: 804 / 11,939 Data Transferred (Sent/Received) [MB/GB]: 497.08 / 4.45 Output Power (Up/Down) [dBm]: 12.2 / 20.8 Line Attenuation (Up/Down) [dB]: 16.8 / 34.0 SN Margin (Up/Down) [dB]: 5.8 / 6.1 System Vendor ID (Local/Remote): TMMB / ---- Chipset Vendor ID (Local/Remote): BDCM / TSTC Loss of Framing (Local/Remote): 86 / 0 Loss of Signal (Local/Remote): 18 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): - Error Seconds (Local/Remote): 2,035 / 23 FEC Errors (Up/Down): 89,370 / 10,336,528 CRC Errors (Up/Down): 580 / 11,610 HEC Errors (Up/Down): 1,722 / 64,276
