REIN trouble (mostly fixed)
- REIN trouble (mostly fixed)
Re: REIN trouble (DLM strangely inactive)
09-07-2013 6:54 AM
Edit: I did think to check wifi uptimes, which can be seen from scan results, which didn't reveal anything. Mostly surrounded by BTHub3 units, but the nearest neighbour probably has a sky adsl router as old and similar to my netgear.
10-07-2013 8:04 PM
13-07-2013 8:22 AM
The interference no longer has any significant impact on the broadband besides the stat graphs. It may have been fixed by:
- The maximize INP tweak actually did something.
- Removing the cover of the junction box to take the photo moved some wiring.
- The line test on Friday did something to the interleaving settings.
- Something else entirely, maybe the source of the interference was moved, fixed, shielded better, or a marginally faulty component got a bit better by itself.
Some of the theories don't quite tie in to the time the problem went away or the fact interference is still detectable with an AM radio.
Re: REIN trouble (mostly fixed)
24-07-2013 6:40 AM
07-09-2013 7:29 AM
At 7am yesterday I decided to remove the +2db extra noise margin tweak, returning closer to the default settings of the netgear, which might have been bad timing as that might have been the time the interference started up. This resulted in a slightly higher speed, but also about 49618 error seconds out of 86400, 58%, which probably isn't very good.
[tt]AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 684 DS Connection Rate: 3814
DS Line Attenuation: 60.7 DS Margin: 6.0
US Line Attenuation: 37.1 US Margin: 5.0
US Payload : 115972512 DS Payload: 1354765344
US Superframe Cnt : 5126747 DS Superframe Cnt: 5126747
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 49618 Severely Err Secs: 3494
Frame mode: 0 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1613
Trained Mode: 16 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 3
Hybrid Selected: 3 Trellis: 1
Showtime Count: 1 DS Max Attainable Bit Rate: 4088 kbps
BitSwap: 1 US Max Attainable Bit Rate: 1089733 bps
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -366
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 54 53 54 43 05 10
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 21 FEC: 330980 NCD: 0
LCD: 0 HEC: 23
[Downstream (RX) Interleave path]
CRC: 295027 FEC: 149536316 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 2416094
Idle Cell Cnt: 138182524
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 0
[Downstream/RX)]
Good Cell Cnt: 28224278
Idle Cell Cnt: 755659010
Bad Hec Cell Cnt: 177531
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 705663
Rx PDU's: 1014576
Tx Total Bytes: 81815268
Rx Total Bytes: 1299389505
Tx Total Error Counts: 0
Rx Total Error Counts: 17973
[/tt]
07-09-2013 12:02 PM
08-09-2013 7:48 AM
I have REIN problems at the moment which started a few weeks ago, almost as soon as new neighbours moved in to the house next-door-but one. The REIN has settled into a pattern where the source is on for an hour or two in the early morning and again for a similar time period in the late evening but exact timings vary from day to day. Sometimes it is on during the day also, but not too often. Today is a Sunday and they haven't switched it on yet, which is unusually late - must be having a lie-in. I am running Routerstats 24/7 on my computer and the transitions, which typically add about 4dB of extra noise, are very obvious. I have wandered round my house and my area with a MW radio when the noise source is on and when it is off so I could tell you what I experienced. I have approached my neighbours but they rapidly became defensive at the notion that something in their house could be causing a problem. Oh, and just before they moved in they had their guttering replaced, which would have scared-off any birds nesting on the roof!
Anyway, I would be happy to compare notes if you wish.
08-09-2013 8:19 AM
After openreach re-did the connections for the star wiring on Thursday, to fix the telephone, I made the mistake of seeing if I could stop increasing the noise margin by 2. While the broadband was completely unusable, obviously the DLM was happy to sit around doing absolutely nothing. But after 27 hours of being connected at 3814k, the DLM decided that was too fast, and decided it needed to jump in and fix that, and slow things down, by increasing the noise margin by 3.
The noise margin will probably go back down after a couple of weeks if I leave things alone, and hopefully the interference will have gone away by the end of September anyway.
08-09-2013 10:47 AM
My noise source might go off to university at the end of September - I am very much hoping so.
14-09-2013 7:29 PM
15-09-2013 8:44 AM
[tt]US Connection Rate: 882 DS Connection Rate: 3678
DS Line Attenuation: 58.6 DS Margin: 6.0 (+2)
US Line Attenuation: 36.9 US Margin: 5.2
[/tt]
15-09-2013 8:52 AM
15-09-2013 9:49 AM
INP = Impulse Noise Protection
INM = Impulse Noise Monitoring
INS = Impulse Noise Sensor (according to the ITU G.992.3 PDF)
15-09-2013 10:33 AM
There's no harm so long as nobody takes it seriously.
Post #25 in the YouTube thread was a bit of a classic too.
The clue, if one were needed(!) is in the studious shunning of sentence case - that's what the Millennium Dome Experience content designers did to show they were taking the Michael too
15-09-2013 10:35 AM
