RE: Is it Time To Go - For James!
- RE: Is it Time To Go - For James!
24-08-2009 3:52 PM
Thanks very much for your phone call. Would you believe within minutes of you coming off the phone, the connection went! I have noticed that the sync rate also changed and is sitting at 8128/448 now, rather than the 8064/448 I mentioned on the phone.
I'll keep an eye on the throughput over the next day or two and see what happens - hopefully as suggested it will increase duly.
I'll take a look at the options regarding the other bits, and progress that - if you could keep an eye out for it I'd appreciate! No chance of the free router I guess
Again, thanks - *that* is how customer support should be done - perhaps the seniors lurking can take note and use James (and Mand earlier) as examples of how the rest should be doing it?
Bill.
Re: RE: Is it Time To Go - For James!
24-08-2009 3:55 PM
Thanks. I don't think the resync is a bad thing actually. If the profiling works as it should you'll now get a profile of 7150Kbps as opposed to the 7000Kbps you would have got otherwise.
Please do let me know should you decide to place an order and I'll keep an eye on things.
24-08-2009 4:08 PM
Couple of questions - if I use the online product thingy, can I set the change to take effect at the next billing period (30th)? Just looked at the BT billing and that's good to go - they owe us!
Just let me know what the best way to proceed is if you can.
Bill.
jim:quote
24-08-2009 4:13 PM
24-08-2009 4:15 PM
Basically, when you request the upgrade, we'll place a transfer in order for your telephone service. The home phone will then take upto a couple of weeks to be transferred in and it's unlikely that this will happen on your next billing date. However, your first monthly subscription will be a pro rata payment to bring your home phone billing date in line with that of your broadband.
24-08-2009 4:16 PM
Quote So are you saying James has fixed the PPP drop problem?
More of a case of lucky timing I'm afraid Nozzer. BT had recently made an interleaving/SNR change on DirectFS' line, which appears to have reduced/killed any downstream errors and stabilised his line.
24-08-2009 4:19 PM
Quote from: nozzer So are you saying James has fixed the PPP drop problem?
Um....I'll let you know - at present it is doing its yo-yo thing all over again - that's about 7 or 8 drops including two (now) loss of sync in the last fifteen minutes.........
But, allowing a bit for whatever line adjustments were done today, should settle......
....I hope!
Bill.
24-08-2009 4:21 PM
@James.. "More of a case of lucky timing I'm afraid Nozzer. BT had recently made an interleaving/SNR change on DirectFS' line, which appears to have reduced/killed any downstream errors and stabilised his line". Thst sounds as though the DSL was dropping rather than the PPP?
jim:quote
24-08-2009 4:22 PM
It's possible that your router is now trying to synchronise at a speed that's too quick for it to hold onto. Hopefully it should stabilise at a sensible speed.
Off home in a minute, but I'll be online later on.
24-08-2009 4:23 PM
Quote from: Jameseh
We hope! Can you check the logs James if still there?
Specifically last half hour since our phone call.
And thanks for the info on the other.
Bill.
24-08-2009 4:25 PM
Quote from: nozzer Is that the DSL that's dropping/resyncing or just the PPP on its own? I'm not certain whether you were suffering from line instability or authentication problems?
Actually seems to be a bit of both - I've just watched it drop PPP, holding onto sync, then drop sync, re-sync null (0/0) then re-sync just below 8k, and a whole host of PPP reconnects.
Probably another one before this goes on too!
Bill
jim:green multiple quotes removed to match the quotes removed from the quoted post mod:end
24-08-2009 4:26 PM
Quote from: Jameseh
That definitely sounds like a DSL instability problem! I'm not sure now whether we've been talking about the same thing all along here.
24-08-2009 4:29 PM
Previously, we've definitely been on the same page - it was all PPP with sync remaining constant up until this last little bit now.
Bill.
jim:quote
24-08-2009 4:29 PM
That's exactly what mine was doing when I first went back to BT IPS. Cured by transferring to PPPoE!
25-08-2009 8:52 AM
It's not looking so bad this morning - almost 7 hours long on the back of an 8 hour connection from around 6pm yesterday.
From 3:37pm till 4:31pm it was flapping.
This line has stabilised out (hopefully) at 7.5Mbps. We'll see how it behaves across the day.
