Quickie: How to telnet TG585 v7
- Quickie: How to telnet TG585 v7
16-03-2011 7:51 AM
Can anyone tell me what the full command, user name and passwords are?
I tried telnet 192.168.1.254 admin and the router's allocated password and got stuck with the potty picture.
Message 1 of 9
(5,022 Views)
8 REPLIES 8
Re: Quickie: How to telnet TG585 v7
16-03-2011 12:38 PM
The picture means you've logged on to the router From there it's a matter of knowing what commands will do what - I think hitting enter with an empty command brings up the list of available commands on the router for you.
Message 2 of 9
(1,025 Views)
16-03-2011 1:10 PM
Hi! Tried that, but when the pic appears also is below the dotted line "admin>". Hitting return with no further command just takes me round to the same.
Message 3 of 9
(1,025 Views)
16-03-2011 1:39 PM
Try typing 'help' for a list of commands (I tjhink this works on my v8).
Call me 'w23'
Message 4 of 9
(1,025 Views)
16-03-2011 1:52 PM
Yes, help should work or just a question mark ?
You can move into a command group by entering just the group name, and two full stops .. exits that group selection.
If you change anything it is necessary to enter saveall to make the change 'stick' across restarts.
David
Message 5 of 9
(1,025 Views)
16-03-2011 7:53 PM
lucerne, what exactly are you trying to do/change/configure?
Configuring the router via telnet is not a simple exorcise... If you don't know what you are doing you can easily render the box unusable.
Message 6 of 9
(1,025 Views)
17-03-2011 8:09 AM
Hi Peter!
What I want to achieve, if it is possible :-\, is retention of the information in the router's event logs for a longer period than is standard. The thought of doing this arose in connection with the events in the yet to be responded to thread (except ny my addition) "Last 24 Hours". I heard that the logs could be emailed to me.
Knowing myself, though, it's not unlikely I am uo a tree.
Message 7 of 9
(1,025 Views)
17-03-2011 1:57 PM
By default the router retains much more log history than is shown by the web interface. This can be displayed in the command window by telneting into the router then entering systemlog show at the admin prompt.
You can copy the display (right-click, select all, right-click) and paste it into a text editor for saving.
David
Message 8 of 9
(1,025 Views)
17-03-2011 4:17 PM
Thank you very much.
Message 9 of 9
(1,025 Views)
