Quick question on new Fibre install
- Re: Quick question on new Fibre install
02-08-2013 10:23 AM
Phone exchange:
FRASERBURGH
Estimated line speed:
76Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-07-18 16:08:33
Current line speed:
12.6 Mb
When does the current line speed eventually catch up?
02-08-2013 10:54 AM
02-08-2013 10:55 AM
02-08-2013 10:59 AM
Download speedachieved during the test was - 12.19 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 6.26Mbps
02-08-2013 11:01 AM
02-08-2013 11:04 AM
Let me know the outcome of yours, I got told that they can't do it..
Mine are not nearly as bad as your but I got;
Phone exchange:
GRAVESEND
51Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-07-03 21:16:11
Current line speed:
38.6 Mb
When I posted on here saying about being on the wrong IP profile, they went on that I was Banded so that was the max speed I could get.
Hopefully you have more luck than me, but they won't touch mine apparently I am still under DLM.
02-08-2013 11:06 AM
Yours is completely different. The profile on our side it matching that from the DLM, it's the DLM that's banded you and therefore the speeds are lower.
For furrymonkey, it's a simple matter that our profile hasn't flipped to the fibre speed yet. I'm going to do that now.
@furrymonkey
Can you log in to the router and disconnect/reconnect. You should see the higher speeds.
02-08-2013 11:13 AM
My info has been updated..
Phone exchange:
FRASERBURGH
Current line speed:
77.4 Mb
Still no change on speedtest so I will give it a wee while and phone them. Will post results if anything changes.
02-08-2013 11:15 AM
02-08-2013 11:19 AM
02-08-2013 11:22 AM
02-08-2013 11:24 AM
02-08-2013 11:36 AM
02-08-2013 12:22 PM
@Chris - I know I kind off hijacked the thread, but thank you for your response! So once the DLM period has passed can I complain? As Adam tried to explain the whole banding thing, but I still don't understand.
I have had no line issues since I am with you guys, and I don't particularly want to hack the OR Modem to see the stats as to when the DLM would be lifted?
02-08-2013 6:18 PM
Download speedachieved during the test was - 34.57 Mbps
