Question before joining Plusnet Fiber
BigTabs
Can plusnet change settings on there end for fiber aka snr, interleave to fastpath etc
And is plusnet fiber any good for current customers who are on it
Thanks For Reading
Kind Regards
Kyle
Smiley
4 REPLIES 4
apjashley1
Re: Question before joining Plusnet Fiber
Plusnet can change interleaved to fastpath if you request it.
SNR is normally managed by the DLM system - if there is a specific fault with the way this works, they can set a manual SNR target profile.
BigTabs
Thank you for the information apjashley1 much appreciated  Smiley
Kind Regards
Kyle
NorthEasterner
Sorry to be a bit of a div, but what is the difference between, 'interleaved' and  'fastpath'?
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
Oldjim
Resting Legend
Fixes: 63
Sorry to be a wet blanket but on fibre the interleaving and noise margin are set at the cab and Plusnet can't alter it
