Question about Interleaving
- Question about Interleaving
12-06-2011 9:32 PM
I'm just wondering if any plus.net staff member would be able to check if I currently have Interleaving set to on or off?
I requested it be turned off through the member centre control panel (last year sometime?) but notice my router stats say it is set as on:-
[tt]DSL Status Up
DSL Modulation Mode ADSL2+
DSL Path Mode Interleave
Downstream Rate 15160 kbps
Upstream Rate 888 kbps
Downstream Margin 12.0 db
Upstream Margin 13.8 db
Downstream Line Attenuation 32.2
Upstream Line Attenuation 13.6
Downstream Transmit Power 20.6
Upstream Transmit Power 12.2[/tt]
Also from a post on another thread http://community.plus.net/forum/index.php/topic,94202.msg792028.html#msg792028, someone suggested that upload speeds can be capped at 888 kbps if interleaving is on, and 888kbps is also what my router is reporting.
If interleaving has been turned back on, how would I go about getting it turned off as the option to do so no longer appears in the control panel?
[tt]DSL Status Up
Message 1 of 5
(850 Views)
4 REPLIES 4
Re: Question about Interleaving
12-06-2011 10:18 PM
Quote from: rod2040 DSL Path Mode Interleave
Message 2 of 5
(417 Views)
13-06-2011 4:39 PM
Hi rod2040,
I'll place an order for interleaving to be switch off for you.
Jojo
Jojo
Message 3 of 5
(417 Views)
14-06-2011 5:42 PM
Hi Joanne,
thanks very much for doing that,
have just tested it and ping times have lowered from 40ms to 21-22ms,
upload speed has also increased,
many thanks
many thanks
Message 4 of 5
(417 Views)
15-06-2011 8:56 AM
Ah good, You're welcome
Message 5 of 5
(417 Views)
