Question Thread
- Question Thread
Re: Question Thread
25-11-2008 1:24 PM
As I'm pretty happy with my LLU connection my question was more out of curiosity.
I also meant to ask whether it would be OK to revert back to LLU after any 21CN trial, or is it your long term aim to convert all LLU customers to BT?
Re: Question Thread
25-11-2008 1:49 PM
It's not going to be possible to move back to LLU after moving to WMBC (ADSL2+), mainly down to cost implications.
We would however, be able to move you onto an ADSL (21CN or Max) product if there were any difficulties.
Re: Question Thread
25-11-2008 2:37 PM
Thanks.
Re: Question Thread
25-11-2008 4:43 PM
Two posts with questions merged in form the volunteer thread.
@artmo, You may wish to up date your post its now replay #9
Re: Question Thread
25-11-2008 4:57 PM
I'm not entirely sure what that means either!
It sounds rather like "we can't find the information you're looking for!"
Just checked Samknows.com too and apparently there's no date set for your exchange yet.
Re: Question Thread
30-11-2008 10:38 AM
I only ask because I've recently upgraded an account for someone from a residential package to a business package and it changed the IP they will be getting into this trial the week after next I believe and they asked me to check as they use VPN which is important to them.
I told them it shouldn't affect it, am I right?
Oops! sorry could a moderator move this to the correct thread please, forgot where I was.
Post moved to Questions thread as requested. David (spraxyt)
Re: Question Thread
30-11-2008 12:23 PM
Re: Question Thread
04-12-2008 9:19 AM
Moderator's Note: This post (and the answer which follows) moved from the Speed Thread. David (spraxyt)
Re: Question Thread
04-12-2008 9:20 AM
Could I ask that we keep this thread for the comparisons only?
Moderator's Note: The post referred to has been moved with this answer to the Questions Thread, so that the final comment no longer applies. David (spraxyt)
Re: Question Thread
04-12-2008 9:57 AM
BOT - DSL Provisioning 1:23pm, Thursday 27th November 2008
The next action on your Help Assistant Question is due on Thursday 4th December at 9:00am. This Question will remain open with the BOT - WBMC Provisioning until this time.
Additional information is provided below:
We have now placed the order to migrate you onto the 21CN network, this is due to complete in 7 days time.
Script User Automated Script Pool 9:05am, Thursday 4th December 2008
We would like to inform you that your Help Assistant Question has now been returned to the BOT - WBMC Provisioning pool. A member of our Support Team will investigate your issue as soon as possible.
Not sure what happens next but hopefully everything is going according to plan. By the way, what does BOT stand for? Broadband Operations Team at a guess?
Re: Question Thread
04-12-2008 10:00 AM
Is there a way to know that the change has taken place?
My DMT software shows adslctl version 1.0
ADSL PHY: AnnexA version - A2pB023b.d20e
System Type: 96358GW-16
Re: Question Thread
04-12-2008 10:07 AM
You should hear back from them later on today.
Re: Question Thread
04-12-2008 10:08 AM
If that's not changed, I'd suggest that the order hasn't completed yet.
Re: Question Thread
04-12-2008 10:11 AM
Re: Question Thread
04-12-2008 10:41 AM
