Question RE: Fibre Extra
- Question RE: Fibre Extra
17-05-2011 9:11 PM
Looking at my upgrade options I can get Extra Fibre for £21.50 which gives me 120GB.....better than BT which cost £28 for "unlimited" (I believe FUP throttles this after the first 100GB?)
I've tried looking but can't find an answer as to what happens *if* the 120GB (or 40GB on Value) is exceeded? Does in incure additional costs or is it simply throttled ala BT? Also, I can't find the quoted upload speeds for Extra Fibre (BT quotes up to 10Mb?)
Of course, being with Plusnet so long I'd love to stick with them but if BT works out cheaper and has faster uploads then I may consider a switch
Re: Question RE: Fibre Extra
17-05-2011 9:23 PM
Is traffic management used to manage compliance with data caps and download limits? Yes Under what circumstances? If a customer reaches their allowance and has set a maximum spending limit Level of speed reduction? 256Kb/s across all traffic types Duration of speed reduction? Speed reduction in place at all times until next billing date.
Extra bandwidth costs £5 per 5GB, and you set the maximum spend each month in your control panel.
BT's unlimited used to have a FUP limit at 300GB, but that has reputedly been removed. I've not seen confirmation though...
The standard upstream rate on both value & extra is 2Mbps.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
17-05-2011 9:36 PM
Yes, this is true! BT Total Broadband and BT Infinity customers will benefit from the removal of Fair Usage Policy (FUP) controls when they begin to be removed from April 2011. Once removed, heavy user customers will be able to download/stream as much as they wish without having their speeds restricted.
BT will remove the FUP controls currently applied to customers with ‘atypical’ usage. Today atypical users are restricted at 300GB usage and account for less than 0.5% of the BT customer base. BT will not target any individuals with restrictions based on usage levels. However, we still have traffic management policies that will restrict certain applications / protocols, such as P2P, when the network is busy.
As BT continues to invest in the network and network bandwidth we can now remove these restrictions and ensure the experience of the wider customer base.
(Note that charges will still apply for going over limits on BT Total Broadband Options 1&2 and BT Infinity Option 1 but traffic will not be managed.)
Thx
Kerry
post 18
http://community.bt.com/t5/BB-Speed-Connection-Issues/BT-TO-SCRAP-300GB-LIMIT/m-p/141429#M65392
17-05-2011 10:00 PM
I thought BT Infinity FUP only went up to 100GB, 400GB is more than enough for anyone I would have thought!
As for the throttling of Plusnet to 256Kb/s.....does this still apply if you have purchased "extra" bandwidth at £5 / 5GB? or so long as you purchased this beforehand, do the speeds remain the same?
Must admit, the 400GB FUP @BT plus 3mths free plus no setup fee (£25 for me with Plusnet) makes is almost the same cost over 18mths......Can't see why I'd go with Plusnet when BT are offering an extra 280GB?!?
17-05-2011 10:38 PM
17-05-2011 11:24 PM
Well no, obviously if you've purchased the extra bandwidth, you don't get throttled.
Quote from: stranex As for the throttling of Plusnet to 256Kb/s.....does this still apply if you have purchased "extra" bandwidth at £5 / 5GB? or so long as you purchased this beforehand, do the speeds remain the same?
18-05-2011 11:00 AM
Don't forget, regardless of other companies' usage limits, from midnight-8am our usage is unmetered and doesn't count against your allowance. Bearing this in mind, if you were scheduling downloads overnight you could potentially be using far in excess of the allowance.
Jojo
18-05-2011 1:45 PM
18-05-2011 2:49 PM
Now i'm on fibre at 37mbps i can get around 4.0-4.5mb download speeds, between 12-8am i can get a free leech of 80gb+, Times that by 30 days per month and we have around 2400 gigabyte or 2.4 terrabyte, lol you lot do the math!
So with my pro addon i can get access to 2.4tb of internet usage per month for £41ish i think it is.
This was the reason i went with plusnet and it's changed my life drasticly for the better!
I think i could do 3tb easily within the free leech period.
18-05-2011 11:54 PM
My only concern is about pn upload speeds. I do a lot of photography so uploading photos is important to me.....bt quote up to 10Mb/s which is obviously attractive vs pn's 2......does anyone know of any plans by pn to raise this is the future?
23-05-2011 9:50 AM
Quote from: stranex does anyone know of any plans by pn to raise this is the future?
We are looking to offer up to 10Mbps upload but as yet have no concrete plans as to any timescales.
Jojo
