Question #77930724 No response
- Question #77930724 No response
Re: Question #77930724 No response
05-12-2013 6:00 PM
06-12-2013 11:29 AM
We can always change it back to 6dB, but if you're seeking to get the extra speed then it is an option.
06-12-2013 2:46 PM
06-12-2013 5:09 PM
Just to let you know that this may take a little longer than a normal SNR reset as we've had to do more of a manual process. Should be within the next 24 hours though.
06-12-2013 6:11 PM
Will check out what difference it makes after work tomorrow.
07-12-2013 12:04 AM
This might be a step in the right direction, however I have my concerns about stability. I strongly recommend that you monitor things with RouterStats. This will constantly measure and record your router performance.
The following might seem like gobbledygook but it is an attempt to explain simply the relationship between SNRM and synch speed, why SNRM constantly changes and why you might see differences in synch speed between modem restarts.
SNRM is not a static value - it will vary minute to minute depending upon the prevailing RFI (radio frequency interference). At night time, there is more RFI thus SNRM falls, in daytime there is less RFI and SNRM rises. When you do a resynch you get the best speed attainable at 3dB SNRM (or whatever is the current target) in the given RFI conditions. At 3db, if you resynch during the day, you run the risk that at night time you will see poor data throughput due to a near zero SNRM and a high level of data retransmission errors. If you resynch during the night, you will see a slower synch speed, but greater stability and the SNRM observers during the day will be higher than 3db.
I would be very interested to see what RouterStats reports for your line. I'm surprised that (if your attenuation is being reported correctly) that you are not getting another 4Mbs synch speed. However, let us see what the 3dB SNRM reset does for you.
Cheers,
Kevin
07-12-2013 12:57 PM
Have checked Thinkbroads quality graph I have set up to confirm
My Broadband Ping
Have had more issues in the few MONTHS I have been with Plusnet than all the years I was with BE. Very disappointed as I had just closed the ticket
07-12-2013 4:01 PM
I've done thus with several 'non-supported' devices.
07-12-2013 4:29 PM
07-12-2013 4:36 PM
HTH
07-12-2013 6:44 PM
07-12-2013 6:59 PM
Ah well, there you go, you need to be careful what things mean around here... Before I go making rash assumptions, I need to check something with you...
Have you got a fixed IP address supplied by PN? If the answer is no, then that ping graph is not going to be yours. I do not want to sound like I'm teaching you to suck eggs, but I do want to be sure of what I'm basing my conclusions on. Far too many times in life I've made complex conclusions of IT problems, only to find that when I check for myself, information I'd been given was (at best) flawed!
If you do have a fixed IP address then I think I can explain the difference as follows... The ping plot requires that your modem has a DSL session with the BT exchange (DLM) and a PPP session with PlusNET so that ping messages reach your router. The system up time could be reporting one of two other things...
1. The switched on duration since the last reboot.
2. The elapsed time since the last DSL resynch.
Either of these could well be different from the elapsed time since the last PPP session was established, which is reflected by the ping graphs to YOUR FIXED IP address.
How are you making out with RouterStats?
07-12-2013 7:10 PM
Had a look at the instructions and vaguely understand them, but cannot seem to get the correct URL for the stats
07-12-2013 7:16 PM
You might want to have a read around there, if you are interested in the technical detail of ADSL - lots of useful stuff here.
08-12-2013 3:39 PM
Would be interested if staff could explain the downtime as nothing occurred in the house or surrounding area to cause the disconnection.
