Puzzling TBB ping monitor
- Puzzling TBB ping monitor
31-08-2014 11:37 AM
Yesterday the Ping graph looked normal whilst I was in the building and then it looks as if not long after I left it started up again, I went back about an hour later and did a couple of speed tests which were typical for the line and switched wifi off totally, leaving only a vodafone sure signal connected to the technicolor router which will be the next thing I will try disconnected to see if that alters in the graphs.
In the mean time I am slightly puzzled, as it stopped around midnight, and now has started up again around 10am.
Line syncs at 8128/448 on adsl max, and is fed from a pole right beside the building but is due to be moved underground, and the line sounds reasonably clear. Will get full line stats next time I am past in case those can help highlight anything. Filter is an nte2000
My Broadband Ping
Re: Puzzling TBB ping monitor
31-08-2014 11:43 AM
Do you have DMZ set up to a wireless device? Your base ping looks very high there.
31-08-2014 11:52 AM
Here is Friday and Saturdays graphs as well.
Friday
Saturday
31-08-2014 7:43 PM
Line stats from the Technicolor router
Uptime: 3 days, 7:53:12
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [GB/GB]: 1.60 / 16.53
Output Power (Up/Down) [dBm]: 12.0 / 11.9
Line Attenuation (Up/Down) [dB]: 3.0 / 6.5
SN Margin (Up/Down) [dB]: 28.0 / 12.9
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 26 / -
Loss of Signal (Local/Remote): 3 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 36 / -
FEC Errors (Up/Down): 5 / 2
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0
31-08-2014 8:29 PM
Edit: I take it your exchange is not 21CN yet?
31-08-2014 8:43 PM
Yeah exchange hasn't been upgraded for 21CN and there is no plans for 21CN, unless it comes along with FTTC and FTTP in December.
31-08-2014 8:50 PM
Do you have many machines running behind the network? Would it be possible to turn them all off and see what happens?
That is a high ping for such a good line - I assume this is down to the fact that you're on an older 20CN exchange.
31-08-2014 9:04 PM
On a normal day there is usually at most 2 machines and possibly a couple of iPads or iPhones at any given time so it doesn't get heavy usage. The graph from Friday from 8am to 6pm is what it normally looks like when the broadband is in use.
31-08-2014 9:14 PM
31-08-2014 9:24 PM
01-09-2014 12:59 AM
01-09-2014 12:39 PM
01-09-2014 5:03 PM
04-09-2014 4:54 PM
Pinging bbc.co.uk [212.58.246.104] with 32 bytes of data:
Reply from 212.58.246.104: bytes=32 time=61ms TTL=56
Reply from 212.58.246.104: bytes=32 time=141ms TTL=56
Reply from 212.58.246.104: bytes=32 time=114ms TTL=56
Reply from 212.58.246.104: bytes=32 time=58ms TTL=56
Reply from 212.58.246.104: bytes=32 time=53ms TTL=56
Reply from 212.58.246.104: bytes=32 time=90ms TTL=56
Reply from 212.58.246.104: bytes=32 time=65ms TTL=56
05-09-2014 9:11 AM
Here is the results of pings taken around 8pm and 10pm last night
Reply from 212.58.246.104: bytes=32 time=282ms TTL=56
Reply from 212.58.246.104: bytes=32 time=293ms TTL=56
Reply from 212.58.246.104: bytes=32 time=294ms TTL=56
Reply from 212.58.246.104: bytes=32 time=133ms TTL=56
Pinging plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=212ms TTL=248
Reply from 212.159.8.2: bytes=32 time=198ms TTL=248
Reply from 212.159.8.2: bytes=32 time=241ms TTL=248
Reply from 212.159.8.2: bytes=32 time=236ms TTL=248
Pinging bbc.co.uk [212.58.244.18] with 32 bytes of data:
Reply from 212.58.244.18: bytes=32 time=413ms TTL=55
Reply from 212.58.244.18: bytes=32 time=489ms TTL=55
Reply from 212.58.244.18: bytes=32 time=574ms TTL=55
Reply from 212.58.244.18: bytes=32 time=507ms TTL=55
Reply from 212.58.244.18: bytes=32 time=353ms TTL=55
Reply from 212.58.244.18: bytes=32 time=393ms TTL=55
Reply from 212.58.244.18: bytes=32 time=428ms TTL=55
Reply from 212.58.244.18: bytes=32 time=441ms TTL=55
And a speed test at 10pm
Is there anyway to find out if there is any congestion at the exchange? The exchange checker on usertools gives green. Exchange is NSSNS
Also it looks like interleaving might be on this line, but the stats in my opinion look good so would it be possible to try interleaving switched off?
