Puzzled??????
- Puzzled??????
- « Previous
- 1
- 2
- Next »
Re: Puzzled??????
24-03-2013 7:26 PM
No Andy. I get varied results at all times.
I am an early riser and am getting these low reading as early as 5am.
Message 16 of 21
(313 Views)
Re: Puzzled??????
25-03-2013 2:07 PM
Hi smufter,
I can see we're currently dealing with your fault ticket, so we should have an update for you soon.
Message 17 of 21
(313 Views)
Re: Puzzled??????
27-03-2013 8:59 AM
Hopefully Chris
It's still "as bad".
Message 18 of 21
(313 Views)
Re: Puzzled??????
27-03-2013 11:44 AM
Thanks for the reply on your ticket and confirming that nothing else was using you connection at the time of your speed tests. We're currently testing your line and we'll update you again pronto.
Message 19 of 21
(313 Views)
Re: Puzzled??????
03-04-2013 7:15 AM
Stupid question maybe, but could my choice of browser be causing this issue???
I use Firefox, and all of my speedtests have been carried out via this. Just out of curiosity I carried out a couple of tests using IE and Google Chrome. Both of these speedtests showed download speeds of just over 70Mbps.
I have been back into Firefox and disabled all of my "add ons" and "extensions" except for Flashplayer (which I need to run the speedtests) and again it is showing speeds of just over 40Mbps.
If this is the case I know the simple answer would be to use either IE or Google Chrome but I much prefer the layout of Firefox with regard my "favourites" etc.
Message 20 of 21
(313 Views)
Re: Puzzled??????
03-04-2013 8:16 AM
I used to get the same problem when I was on Firefox I'm on chrome now and it's fine the only thing about chrome is it does use alot of memory
Message 21 of 21
(313 Views)
- « Previous
- 1
- 2
- Next »
