Public IP address changes every day
- Public IP address changes every day
24-12-2011 2:39 PM
Have a problem with the public IP address changing every day.
I dont want a static IP address, but is there a way to at least make it so that it doesnt change every day.
Re: Public IP address changes every day
24-12-2011 2:40 PM
For best speeds it's recommended to leave your router on 24x7 anyway.
26-12-2011 1:14 PM
Is there a setting in my router that i need to change?
26-12-2011 1:16 PM
26-12-2011 6:10 PM
Have you checked that your router doesn't have a connection timeout set?
27-12-2011 5:02 PM
and how do i check if there's a connection timeout set?
27-12-2011 5:33 PM
If it is the Plusnet one then look at Event Logs
27-12-2011 6:50 PM
Why is that a problem to you ?, when you specifically don't want a static IP address.
28-12-2011 10:34 AM
Your IP address only changes when there's a connection drop. As you can see from the graph below this has only chaned twice in the last eight days.
Jojo
29-12-2011 3:14 PM
Thanks for your reply.
I am in the development team for software company. The only people who can access the software/site are people who have their ip address enabled meaning no one else can access the site/software.
With the problem i am having, it means everytime i try to access this from home, i have to contact the developers to enable the ip address i am at.
So far everytime i have tried to access the site, it does not allow me as my IP keeps changing, therefore i know that my IP address is changing every day as i need to find it everytime i need to access it.
Joanne, im sure if you look at my previous posts it will tell you that each time i have posted, there is a new IP address (if there is a function to see that).
If your system says that my connection has dropped twice in the past eight days, it means there is a setting on my router which is expiring the IP, no?
29-12-2011 3:25 PM
To summarise
IP address 1 - posts on 26th Dec and 29th Dec
IP address 2 - post on 27th Dec
IP address 3 - post on 24th Dec
IP address 4 - post on 21st Dec
29-12-2011 3:33 PM
29-12-2011 3:38 PM
29-12-2011 4:16 PM
Sorry, just realised you're on Value, static IP not available on there, my bad
Jojo
