Profile stuck? any suggestions?
- Profile stuck? any suggestions?
Re: Profile stuck? any suggestions?
19-04-2011 4:44 PM
i'll run another test when i get home (~45 mins) and in case i'll post on the ticket followup
19-04-2011 5:28 PM
Today 08:13 270 kbps (33.8kB/s) 367 kbps (45.9kB/s)
Today 07:13 278 kbps (34.8kB/s) 369 kbps (46.1kB/s)
still nothing better, will post this in the ticket
20-04-2011 8:07 AM
Thanks for that. I'll see what can be done with this today for you.
Jojo
20-04-2011 8:53 AM
thanks for this. We just re-synced at an higher rate about 1 hour ago and so decided to run another test but still same results as yesterday.
it just looks like as although the profile has been raised and SNR reset, the delivered bandwidth is still throttled. The results of the tests are way too close together.
20-04-2011 10:55 AM
I'll do what I can to make sure we get to the bottom of this for you.
Thanks for your patience,
Jojo
20-04-2011 12:10 PM
I've been on to BT and still can;t find what might be causing that. I've explained all that's happened to one of the faults guys and he's picking it up for me, so hopefully we'll get a bit further on.
Jojo
20-04-2011 1:38 PM
well not much of a surprise but i just checked the router again and it had re-synced 1 hour and 45 minutes ago at 284kbit, so looks like we are back to basic
i have to say it's not really much patience but more like we kind of lost hope
20-04-2011 6:46 PM
profile is back at 0.25 Mbit! Not that we got much more out of our higher sync rates but at least it gave a little bit of hope that something was going to happen.
I'm starting to think that there is a serious problem with the exchange, over the top saturation?
as the upstream is stable at nearly twice the downstream, with previous experiences this is what i think the problem is!
If this reduction is going to be blamed again on the DLM than i guess whoever came up with the idea of using such a service should reconsider his career in IT as it's clearly not working or perhaps PN customer support should be given a better training on what the DLM stands for and how it performs.
Never the less it took 2 weeks to actually get someone to finally understand that the problem was that our profile was stuck and not that we needed a visit from a bt engineer but i guess as per above that is some kind of "computer says no" answer.
i would suggest to anyone consifdering moving to a higher speed package to not do it, we had a reliable 8Mbit connection which was upgraded to 0.25 Mbit, yes you did read right!
21-04-2011 11:35 AM
My suspicion is that it's not DLM but a system issue where the part we see shows as everything hunky dory and the part we don't see keeps banding your line, which then confuses everyone. I'm on with our suppliers at the moment trying to get to the bottom of this for you.
Jojo
21-04-2011 11:39 AM
thanks for keeping an eye on this. I guess we are in re-sync now as i can't get to the routerstats infos now (remote view), will check again.
what seems odd is that we jumped from 14xxxKbps to 254Kbps straight wityhout any intermidiate steps and that the line throughout speed has never changed even when synced at 14KB
21-04-2011 11:43 AM
21-04-2011 11:44 AM
21-04-2011 10:21 PM
just managed to get back and check the situation. router seems to be able to cope with the sync rate but yet no signs of increased bandwidth delivered. latest speed test results:
System Up Time 27:34:58
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoE 42836 31102 0 377 798 09:57:38
LAN 10M/100M 1076328 646911 0 4391 1130 27:34:53
WLAN 11M/54M 250043 226549 0 1261 423 27:34:43
ADSL Link Downstream Upstream
Connection Speed 15140 kbps 445 kbps
Line Attenuation 23 db 7.5 db
Noise Margin 6 db 25 db
Today 22:13 274 kbps (34.3kB/s) 361 kbps (45.1kB/s)
Yesterday 08:14 276 kbps (34.5kB/s) 365 kbps (45.6kB/s)
Tuesday 17:27 264 kbps (33kB/s) 367 kbps (45.9kB/s)
i also tried with my dedicated server and won't get past 30KB/s down. I know for a fact that the server has at least 95Mbit of upstream b/w available as i'm live monitoring it
26-04-2011 7:31 AM
26-04-2011 3:11 PM
Could you tell me what make of router you're using?
Jojo
