Profile raised again please
su4stu
Once again Plusnet has my profile at 4500 and BT has it at 5000!  I know that my sync speed dropped a few times but what I don't understand is BT hasn't yet lowered my ip profile but as soon as I was syncing at the lower speed Plusnet lowered my profile at their end. I thought Plusnet changed the profile according to what BT had?  Anyhow I was wondering if I could have it raised again?  Many thanks  Smiley
16 REPLIES 16
jojopillo
Re: Profile raised again please
The BT systems are showing 4500, can you post a BT speed test result? Smiley
su4stu
Hi Jojo.  As you can see my ip profile is 5000, which it has been for weeks.  This happened last week, Plusnet lowered it to 4500 even though it was still at 5000 with BT.
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
3895 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3895 Kbps
Additional Information:
Your DSL Connection Rate :5504 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
spraxyt
Resting Legend
Fixes: 75
For a sync speed of 5504kbps the IP Profile should be 4500kbps which Jojo said was the value reported by the BT systems. So it looks like there is a mismatch across the BT systems.
Sadly I imagine the values will be reconciled at 4500kbps unless you have scope to achieve a sync speed of 5696kbps (current noise margin around 1½dB above the target value).
David
su4stu
I'm aware my sync speed is too low for a 5000 ip profile but for some reason it's syncs at about 5900 in the morning and then lowers by evening. Has anyone any idea what causes this?
su4stu
Okay I just rebooted my router and these are the latest results from BT. Smiley
Download  Speed
4631 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 4631 Kbps
Your DSL Connection Rate :5952 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
spraxyt
Resting Legend
Fixes: 75
It is normal for noise margin to vary between daytime, evening and after dark. Electrically induced noise tends in increase when people come home from work and turn on equipment needed to sustain modern life. After dark environmental issues cause more radio frequency noise (one can often receive foreign AM broadcasts, for example). Since the signal strength does not change, increased noise leads to reduced noise margin. This makes it more difficult for the modem to 'hear' the signal. However the target value and router/modem performance normally allow a small reduction in noise margin (1 or 2dB) to be accommodated without sync being lost. If sync is lost the the sync speed will be lower (to restore noise margin) when sync is regained.
Is your router one that works with the RouterStats monitor, eg the Thomson TG585v7 or v8 supplied by Plusnet?
David
su4stu
I'm using the netgear N300.  Not sure if it works with routerstats, I'll check tho.
su4stu
Yes it is Smiley  Do you think I should keep an eye on my stats for a few days?
spraxyt
Resting Legend
Fixes: 75
Now you have a reasonable sync speed supporting an IP Profile of 5000kbps I suggest avoiding router restarts for as long as you can.
Checking on how noise margin varies with time would be useful, in case the value drops low enough to cause loss of sync. RouterStats provides constant monitoring if you can get it to work with that model of router. This post provides a guide to configuring RouterStats.
David
jojopillo
Hi su4stu,
The line's now syncing at 6080 but it's only been connected for 16 hours so far. It'll need to be a little longer before the IP profile picks up.
Jojo Smiley
su4stu
Thanks for the help  Smiley I'll leave the router and hopefully my profile will go up soon.
su4stu
That's my router had a steady connection of 5856 kbps for 76 hours now.  BT has had my ip profile at 5000 for ages but Plusnet still has it at 4500.  Huh  Could you raise it for me now please.  I've posted my latest results from BT below.
Download  Speed
3798 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 3798 Kbps
Your DSL Connection Rate :5856 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
jojopillo
Hi su4stu,
This is part of a problem we have raised with our supplier. I'll keep you informed when we have more information.
Jojo Smiley
su4stu
Thanks Jojo.  Is this to do with usage allowance or a line problem?
