Product change
- Re: Product change
Product change
14-11-2012 2:11 PM
Whether its the increasingly bandwidth intensive nature of websites or a PC that is no longer up to the job, I've been finding web browsing speeds frustratingly slow recently. Is it time to change from my current 'up to 8Mbps' connection which actually runs at only 1.75Mbps, or should I take the plunge and spend an extra £10 per month for fibre?
What I would like to know is why the member centre reports my current connection of achieving 2.5Mbps download with 1 Mbps upload. I've never had a sync rate above 2.3Mbps or a profile above 2Mbps. What can I do to achieve such dizzying speeds as those suggested? Even the BT speed checker quotes a range from 1.5 to 3.5Mbps.
My other car isn't a Ferrari
Message 1 of 4
(784 Views)
3 REPLIES 3
Re: Product change
14-11-2012 4:55 PM
We can try moving you onto ADSL1 on 21CN rather than the current 20CN you're on to see if that makes any difference. I'd be reluctant to try ADSL2 though but any such orders to move between these services can be done with 1 working day's notice so let me know if that's something you thing you might want to try.
Adam
Adam
Message 2 of 4
(362 Views)
Re: Product change
15-11-2012 1:40 PM
Thanks Adam, but if I have to stick with ADSL1 I'd rather stay on 20CN.
I guess the estimate of 2.5Mbps d/l and 1Mbps u/l only applies if it were possible to move to ADSL2+. I understand any improvement would be marginal and the risk of degradation or poor speeds due to the way the MSAN operates does not make such a move worthwhile.
Message 3 of 4
(362 Views)
Re: Product change
15-11-2012 3:49 PM
The advantage of ADSL1 on 21CN is that instead of the big steps in IP Profile you get on 20CN it is always 88.2% of the current sync. If you are just below the speed to go up to the next step, moving to 21CN can make a significant difference.
Message 4 of 4
(362 Views)
